Originally posted by Duncan
It is interesting that the guys in the Z came 7th outright on the back of excellent performance in the wet tracks. Their results on the dry tracks were mid field but there were about 40% wet events.
...(and take a gtr for traction....) ...
The wet events are a great leveler in terms of power and skill. 600hp isn't going to help much if all it provides is wheelspin. :burnout:
Smooth driving and using the available traction to full effect is the key. The GTS-t seems to be nicely balanced and able to get the power down effectively in the wet events. The porsches do so well as they have an engine hanging out over the rear axle and as such can get traction. Same reason for the Mini doing well and Renault Clios in other events. The Clubman had no chance in the wet events (~280hp and ~600kg :cheers: ).
wet events were all about tyre choice
one of the quicker cars was the 7? corvette that had a tyre that had tread death of about 2 inches and it kicked arse on the skid pans
the zed had street trye on and it had some great grip (with no wheels spin) coff traction control coff
also on the zed front here r some interesting facts
on the 800m sprint it actually was 1 second quicker than us and we have 12 psi and a zorst so those zeds aint no slouch in a straight line.. either that or dunk and i cant drive in a stright line
next yea should be interesting in a car with double the power that we had this year
bring it on
pete
Woohoo. Well done to Fatz, Duncan and Dom. Great results guys.
It was plain to see that you guys were struggling for grip on the wet skidpan and figure 8 at EC which makes your results even more awesome.
What are you running next year Fatz? Not the 31?
It looked like great fun anyway and I'm looking into the possibility of running my Hyundai next year. Should be good for a laugh. :cheers:
Cheers,
Ben
Guys, I think the ideal car for FATz would be my little GTI-R. It weighs two of me or three of fatz and I would have to cut a hole through the roll cage for his head to fit.
Come to the Grand Prix rally day at my office in November and take it for a spin.
Id love to stick in a photo but havent worked out this process yet.
bring it on
pete
The Zed had traction control off, so Richard (the driver) told me. The car is a completely standard 'Track' model. Pretty surprising how quick it was down the straight :P ... Overall the Z did pretty damn good considering they only entered the event 2 weeks before it started. It didn't take much convincing for me to be told to enter it next year in my GTR :(
Jono
PS .. if any of you guys got pics of the 350Z please email to [email protected]
Should be a great turn out for skylines next year, theres already a gtr class (class A), but we might lobby for a seperate GTST class as well if there are enough interested :(
Their photos are up at: www.pbase.com/duttonrally/nsw/veh50 If they are interested in sponsorship backing in future they should seriously consider buying the photos, just $65 and they can use it for proposals...
Those guys did a *top* job in the wet, well done.
Just a quick bit of advice.
Do it with OTHER PEOPLES MONEY...
I call on a few companies I know and ask them to sponsor my car for a rally at a fee of $1,100.00 incl GST. They get a tax deduction, some great promotional photos, a copy of a video and to brag that they have sponsorship of a race car. This year for two events i got Over $5,000, free pads and free rotors. (by the way expect 19 out of 20 to say NO)
Th best deal is for $1,500 they also get to come for a spin of the Grand prix circuit
How can they refuse.
Just remember OTHER PEOPLES MONEY!!!
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
