yep, consult cables work, the plug is located with the in cabin fuse box. i've tried a few of the free consult software interfaces and don't remember seeing anything like cold start enrichment. the one i want to get is nissan datascan, it is supposed to be a bit more in depth than the free software getting around.
https://www.sau.com.au/forums/topic/273589-ecutalk/#findComment-4641519
As I understand it any changes you make to a stock ecu with through the consult do not stick - .i.e. once you unplug it and drive off everything returns to default mode. To make changes to settings you will need a nistune chip or for the S1 an expensive daughterboard that can be chipped.
https://www.sau.com.au/forums/topic/273589-ecutalk/#findComment-4641579
yeah, all i can do with the software i have is, switch the auxiliary thermo fan on and off, raise and lower the idle, turn cylinders off, etc. but like kiwi said, its all real time testing that isn't a permanent change. the other major features of the software are being able to read and clear fault codes, and some of the software has data logging capabilities, good for looking at afm voltage or injector duty cycle vs rpm.
https://www.sau.com.au/forums/topic/273589-ecutalk/#findComment-4641708
Ryan - the ECUTalk consults work brilliantly on just about any nissan (with consult ports) and I cant speak highly enough of them. There is a bucket load of other software available that works with their cables, and my personal pick is the original nissan datascan (there are a few others that are pretty good too)
not quite. There is a few things that can be changed with just a consult cable. For instance, the base timing, idle speed and stuff like that can be changed quite easily using just the consult cable.
Search nissan consult on ebay world wide. alot cheaper :P
NO DONT DO EEEETTTT!!
From personal experience, this is a bad idea. I went through 4 ebay specials before I bit the bullet and got the ECUTalk one. Apart from the fact that a lot of other places only use serial ports (and trying to find a usb-serial converter that will talk to them is damn near impossible) they dont all work - I had one ebayer swear black and blue that the unit I returned was not faulty, despite being back to back tested with a known one and no one could get any signal from it (tested on 2 stageas and my pulsar and 3 different laptops)
IMO just get the ECUTalk cable (with USB output) and you wont regret it. If you do want to buy a ebay special just because they are cheaper, I can send you the last ebay one I bought, and didn't bother to return, for free, and then you can have all the frustration without the expense! :down:
https://www.sau.com.au/forums/topic/273589-ecutalk/#findComment-4644400
hmm i think that at the end of the day the "ebay specials" aren't any cheaper anyway if you need usb support. the serial-usb adapter i bought (belkin) was about $50, then the e-bay special consult port was $60ish anyway, so it cost me more that the native USB alternative from ecutalk. then theres software on top of that and the hassle of finding it for free if you're so inclined. AND you're keeping your cash in australia. convinced yet? :P
https://www.sau.com.au/forums/topic/273589-ecutalk/#findComment-4644664
IMO just get the ECUTalk cable (with USB output) and you wont regret it. If you do want to buy a ebay special just because they are cheaper, I can send you the last ebay one I bought, and didn't bother to return, for free, and then you can have all the frustration without the expense! :happy:
So this one? or EcuTalk?
I is lost
http://www.plmsdevelopments.com/consult_if.shtml
http://www.ecutalk.com
https://www.sau.com.au/forums/topic/273589-ecutalk/#findComment-4644873
I cant speak for the PLMS ones, having never actually used one, but I can say that the ECUTalk ones work brilliantly, and even though there is a few bits and pieces you have to do (usb drivers installed etc) making them a little more involved than "plug and play" the step by step instructions are stupidly easy to follow, even for a computer noob like me.
The service you get from NewKleer if you have any installation issues is second to none too IMO. Just get one man, and if you are chasing any software let me know :happy:
https://www.sau.com.au/forums/topic/273589-ecutalk/#findComment-4645058
i'd say either one would be fine, they are both good companies with a quality cable. the only thing everyone is getting at is to get a usb one as a lot of the usb to serial convertors don't work. at the time i got mine they didn't have the usb ones so i got a Blatz brand one and use it with a belkin serial convertor with no problems at all with it.
https://www.sau.com.au/forums/topic/273589-ecutalk/#findComment-4645078
I take it the ECUtalk V2 display is meant to be a permanently connected in car feature - does it display all of the information that would be displayed on a laptop or do you still need a laptop to gain all of the features available via the consult cable?
https://www.sau.com.au/forums/topic/273589-ecutalk/#findComment-4653709
the display is a standalone device, intended to be permanently hooked up (but its plug and play, so u can take it out and plug it into someone elses car to check it) - if you dont want or care to use the laptop with it, you dont need to. it doesnt need a laptop connected for it to work. it can display most, but not all the info that can be shown with software (but since you can use it like a usb consult cable with a laptop if you want, if you need to know anything not shown you can use whatever software on the laptop with the display in USBIF mode).
the only time ive personally needed to hook up a laptop to it was to update the firmware (when there are new features added to the display you can get them via firmware updates), and once to have a play with active tests (changing timing/fuel temporarily)
https://www.sau.com.au/forums/topic/273589-ecutalk/#findComment-4653717
yeah, thats why it was made, so u dont need to lug a laptop around to monitor the car. firmware updates require the display be connected to the car to get power, so youd either need to get the PC within a couple metres of the car, or borrow a laptop. of course u dont need to upgrade the firmware if it has nothing new that you want to use.
also in future if there is logging ability to sd card, you would need power to download the logs also.
if you're that way inclined, u can just buy a 12v dc adaptor and a female consult port from wreckers (or i have a spare one for $10 i can send with display) and rig that up for 12v power
https://www.sau.com.au/forums/topic/273589-ecutalk/#findComment-4653764
That V2 display looks like a pretty good thing.
I've personally got a copy of NDS - which is very handy for diagnostics & dyno tuning (via the 'dashboard' function). It also has another tacho/speedo page with speed-alert which would be excellent if you had a carputer fitted & it was active all the time.
The V2 display would be perfect for the trip-meter function if nothing else.
PLMS have also been playing around with Consult/Nissan ECU's for many years, so they too have a very reputable product lineup.
I reckon I might get a V2 display & permanently mount it in the car.
***edit***
Just bought one...
https://www.sau.com.au/forums/topic/273589-ecutalk/#findComment-4654237
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
