ive bought a set of porshe 996 carera cup calipers and 350 mil rotors as that is the abolute biggest brakes i can fit under the standard r33gtr rim
what i was wondering is how much clearance around the rotors do you need for the rotors to still get good cooling or is clearance not a big issue
the clearance ive got 25 mill right around the rotors and about 5 mill clearance around the caliper is this enough
thanks tim
https://www.sau.com.au/forums/topic/273764-need-help-with-porche-brakes/
im going to run ducting the main reason im asking is every one says you need 18s for the porsch 6 piston brakes but ive got them to fit under the 17s its a tight fit but they fit so i thought there must be another reason they say you need 18s and the only thing i could think of was cooling of the rotors thanks tim
I thought 996 cup cars had the smaller caliper which does fit under a 17. I have a GTR here at the moment with them and 17's
350mm rotors are not that big and you should be able to run a 17 without much trouble.
I use the 997 cup car caliper (the big 6 spot) with a 390mm floating rotor and not many 18's even fit over them.
We've found with more rim clearance rotor temp does drop significantly.
The example I can provide was from my old F50 brembo's with 355mm rotors
17's with approx 5-6mm caliper to rim clearance 15 laps of wakefield rotor temp was 680 degrees.
18's with un measured clearance but clearly more, same driver and laps 1 hour latter. 540degree rotor surface temp.
All laps were within .8second (1:05 sec laps)
they must be 997 calipers then they are the big 6 pot ones
the rotors were 365s but i machined them down to 350 to clear the rims i think ill try them and see how they go and if all else fails ill get some 18 by 10s
thanks for the advice risking
This is a 997 cup car calliper
It has the longer more rounded end on it compared to the 996. Post up a photo of the caliper and Ill be able to tell you which model it is.
The pads are different as well. The 997 cup pad is massive, the 996 is not as big.
There is other 997 turbo brakes around as well which have smaller rotors so perhaps your are from that variety.
The 997 cup cars use 380mm floating rotors so 365's would not be cup rotors.
pretty sure that's a 996 caliper. i've got them on my car (355mm and won't fit under r33 17's), they have a huuge pad, bloody expensive to replace.
Those 100% came from a 997 cup car.
As far as I was aware the 996 and 997 cup cars had slightly different calipers. I know when I tried to put mine over a 355mm brembo rotor the pad did not contact the entire radius so I bought the matching cup rotors straight off the 997 the calipers came from.
Those in your photo are different to mine. The mounting points in mine are at the very very end of the caliper and dont have the raised lugs.
They are 996 cup car calipers. They are indentical to the 996 cup ones I have sitting here.
John at unique had a set of those on his Z and upgraded to the 997 as well.
Edited by Risking
i didnt even think of the pad contact when i machined them down and wont no if they will work untill i acctually buy pads and get my car back from the bead blaster thanks for the help risking
Buying pads is the expensive part.
If you find a few people running the 996 cup cars you can actually buy their second hand pads pretty cheaply to get you going.
The pagids for a 997 are around the 1K mark for a set of fronts.
Obviously a few people are using the 996 or 997 with a 355mm rotor so you should be okay.
That set up will be fine mate. If you are concerned about air flow make up some ducting to run to the rotors this is recomened regardless of how much clearance you have anyway.
with ducting, whats always made me wonder is the temp difference
the inside of the rotor would be cooler than the outside.
I remember Troy (Roy) saying something about this in one of his drunken late night posts in the brakes area but i dont remember there actually being any evidence for/against if there is actually problem with uneven temps that would no doubt occur
The idea of the internal veins is to distribute the heat and channel air through the rotors surface.
I find the pagids to be very good even if I do use the second hand ones. Ive had surface temps of 850 degrees and the pads do start to break up but they are yet to fade. I have not had any pad fail or crumble as yet.
Ferodo and pagid are the only ones Ive used, pagid is better but more expensive.
Main thing I noticed was the pedal feel after 20mins of driving hard. The pagid was fine the ferodo had started to fall away.
Edited by Risking
I can see the diferences now side by side. The 997 pads must be fricking huge, cause the 996 ones are bloody big. I've had pagits (RS14), and hawks. I prefur the Hawks (HT10), the pagits brake up when they get low, havn't had that problem with the Hawks. I think i payed $850 for the hawks
That's why you should ALWAYS point the ducting to the inside CENTRE of the rotor.... The air will go through the vanes inside the rotor to cool both sides of the disc.
Those setups that you see where the ducting points directly at the rotor face is far from ideal.
    • would a r34 gtr hood line up with gt/gtt stock fenders? after latch, front bumper and hinges are swapped for gtr ones? or would the fenders be too low or high in relation to the hood surface? ( I believe seeing somewhere that gtr front fenders use some type of riser for the sides, but do not know how that relates to stock gt/gtt fenders.)
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
