hey all. i picked up a set of coilovers for the stag today, and on top of the hat theres a washer and bolt that goes onto the rod that goes inside the shock, under this washer there should be a rubber stoper peice that stops it clunking when it rebounds. (it pulles the rod back out with it) the way it is now it may chew the support. would i be ok to put some rubber washer things in or what??
there teins btw.
https://www.sau.com.au/forums/topic/273832-missing-a-peice-of-a-coilover/
here we go.. the peice circled and the bit im holding are the same bit, and is what i need! car torque think they may have it.
mike.. ive taken them all apart to clean em up... so there wound all the way down atm... should be ok but ill keep it in mind. any way... not like i should be winding em up far... :)
haha they better be staying low :D
nah, nah, i mean spring compressors for your standard struts if you decide to swap hats
There should be a fat rubber washer either side of the top hat. Which is toped off with a dome washer and nut to compress the washers into the top hat. You could use the washers off your old shocks. Ive done this before. If the top nut goes all the way down the strut shaft then it means you dont have enough packing around the top hats. I have put a few old ones in either side before just to make the rubbers more firm. Otherwise strut will move inside of top hat
thanx guys. i worked out today that the top hats on there are actualy stock lol... so ill just salvage a few bits of mine when they come out... gna b go good to actualy have suspension that works! 4 those who dont know... mine it well past its use by date!
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
