Guys & Girls,
Dyno Day - Aussie VS Imports - Springy Motors has been POSTPONED therefor a standard Dyno Day will take place.
Time: 11:00 till late
Date: Sat 27th of June 2009
Phone: (03) 9546 8777
Cost: $45.00 Free BBQ and Drinks
3 runs and a printout.
Springy Motors will also be starting their DYNO KW ladder board.
Basically all runs from Dyno Days / Tunes will be placed on the board.
The board will also be updated online.
no bookings required, first in first serve.
Spectators welcome!
All makes and models welcome!
AWD Dyno Dynamics Dyno.
A Trophy will be presented to the highest powered vehicle.
Hope to see you guys there!
https://www.sau.com.au/forums/topic/273864-springy-motors-dyno-day-27th-june/
Will be there to spectate. And if my car is ready after its turbo upgrade ill run it
What turbo you getting?
I'll come by, maybe for a run
500kW's... Yeah Abu...
LOL!
I'm in.
Car's mostly stock so not expecting the trophy...but im a little curious =b
Should be good to finally meet some of you =D
Ah good! Get to see your car in the flesh.
might come down an have a look.... if my car is ready might put her on
Got some new mods?
GT3076R
Garrett?
HKS?
Putting some more "GO" in you car instead of just having all "SHOW" LOL! :D
Sounds good, how much boost you gonna be running?
So it pretty much a straight up bolt on as you already got the FMIC, Full exhaust system and a new clutch...
hmmm i will drift it but not HARD OUT dont want to knock it :D
I WANT A ROLLA
Hehehe!!!
Yeah the Rolla is getting a good service and after RWC and REGO, get some custom springs and nice set of wheels.
Ah so that's your grey S14 in the pics from Beast from the East thread...
Yeah that S14 JDM front looks mad.
Garrett?
HKS?
Yea its going to be a straight bolt up really. Got my powerfc coming in from the states.
As for boost i dont know how much i will be running but probably around 20-22 pounds.
Will have it tuned for 98 and then when E85 is readily available ill have it tuned for that at almost 350rwkw hopefully.
Fark yeah!
Hope to see it and see what it pulls on the dyno.
Will be a pleasure...will have to wash her first tho, shes rapidly gotten filthy. Next door keeps having bonfires and ash and tree matter ends up all over my GTR ffs. *angryface*
And aside from that just pray nothing goes wrong hahaha... cuz thatd suck.
Your using the wrong workshop.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
