I heard somethin today about RPM Performance Centre gettin most of its gear stolen from its premises within the past week???
Anyone hear anything about this?
A mate from the 31club mentioned it as we were having our Dyno Day there this saturday but has since been cancelled because of what has happened.
anyone wanna clear this up?
Tim
Well i spoke to the guys are RPM today and they got fuc ked over badly...
It happened after the DYno day. They reckon there wer at least 80 people in the workshop so they would of seen all the stuff they had.
Then afterwards they smashed thru the front door and took everythin.
I feel so sorry for them as they really do such a good job for the tuning scene in adelaide along with the other shops, and i really hate the low life theives that ****en try and ruin other peoples hard work!!!!
I spoke with Ivan yesterday & thankfully insurance will cover everything.
It's a sad fact of life that there are people out there low enough to do this kind of thing. But the really sad thing is there are people who support this kind of activity by buying the stolen gear no-questions-asked :D
I must say my heart skipped a beat for a sec when I first heard the news, seeing as how my car has been sitting in the workshop for months.
Originally posted by EnricoPalazzo
Matt which car was yours? I was there yesterday. What colour line?
My car is the red (well burgundy really) series 1 that's been sitting there since May! The plates read ***** 6, you'll know what I'm getting at if you saw it :D
I can't bloody wait to get it back on the road! And give it a lot of much needed TLC. It looks like a dirty ol' POS atm :(
I'm STILL waiting on my CP forgies to come from the US.
The big news (well it is for me) is I'm keeping the car & will be back on the drag strip as soon as it's run in & ready to go.
Great news whatsisname, I reckon it would have broken your heart to sell it, cos it was nearly breaking mine - too much time, money and love gone there to be giving it away. You never get the true value of a car back when you sell it.
On another note, I think it is a bit harsh to be pointing the finger at the RPM guys, as with any dyno day, it gets publicised and you invariably get all sorts of hangers on coming around. (unless its a boring old SVD one :(:D )
Thanks for the kind words guys :D
I'm REALLY looking forward to being back on the road cruising with you all again.
As for drag strip action...... I'd love to be able to make the 15th Nov AIR meet but the way things are going I don't like my chances :(
From the looks of things (Andrew into the 12's for starters) I've got a lot of catching up to do!!!
I am very happy you're keeping the beast Matt :( .... that is very good news for the summer cruising scene ;) .... who else is crazy enough to have me chasing them through roundabouts down south at 100km/h? :D I can't wait till its back on the road and we can have some runs at AIR!!!
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
