so i finally got around to replacing the front bar on my 33. im pretty happy with how it looks, though the guy who did the work dragged it out for more than two weeks.
for a $275 item off ebay (+p/h) i cant really complain! for those interested, i got the indicators from just jap, i think theyre actually a 180sx side indicator. they blink a bit quicker than normal but its a small price to pay!
https://www.sau.com.au/forums/topic/274527-d-new-front-bar-pics/
Looks the goods...damn your car is low if thats not photo chopped...good luck with driveways :(
its got 100mm ground clearance. the grass is a bit long which makes it appear lower than it really is! even so, 100mm isnt an awful lot, and hence i am extremely paranoid of speedhumps etc.
i measured my exhaust at 70mm lol. it often scrapes on schluthumps.
  • 4 weeks later...
  • 2 months later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
