Just thought i might chuck some pics up on my R34 now with the full Impul kit cos i know there was a lot of interest in this kit with other R34 owners, Just to give them a idea of what it would look like, All parts were bought from PSI parts. Anyway let me know what you think
When i got it
Put bonnet on and eye lids
Then with the body kit on
Needs lowering a little bit but you get the jist, Also looking at carbon boot soon when I have finished with the engine
https://www.sau.com.au/forums/topic/274672-r34-impul-kit/
as with any copy there were some bits that took some modding/cutting to get to fit, prob the worst was the side skirts, but they come up ok I think :) so cant complain there. Just a lot of elbow grease goes a long way. Still undecided on the boot at the moment I think I might need to get a photo shop done :P
https://www.sau.com.au/forums/topic/274672-r34-impul-kit/#findComment-4655890
Mmmm i'm thinking of getting the impul kit as well...
I'd prefer genuine whenever they come around (if it's possible to source from overseas i might!)
But in any case sexy piece of kit i must agree! Love the carbon hood to haha
https://www.sau.com.au/forums/topic/274672-r34-impul-kit/#findComment-4656203
Still undecided on the boot at the moment I think I might need to get a photo shop done :D
me personally I'm not a fan of different colour boot, the tail lights and boot cut out have an unusual shape that looks fine colour coded, but yeah just my opinion It's much cleaner to leave it as is
maybe de-badge? on my old r34 I kept the skyline writing but took off the nissan badge
https://www.sau.com.au/forums/topic/274672-r34-impul-kit/#findComment-4658028
lol must of been teo
looks good man, I even liked it without the kit when u you just changed the bonnet. But looks nice, what size are your wheels?
yes it is. hehehe
i'm still waiting for a frd to get back to me as to when the panel beater can spray paint / quote me a price
https://www.sau.com.au/forums/topic/274672-r34-impul-kit/#findComment-4664801
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
