Hey guys
my 25 turned into a kettle Friday night, head gasket blew, looks like its been on the way for a while, little bit of corrosion on the block under the gasket, looks like the metal ring on the gasket has caught the edge of the piston, not sure if i should pull it down and go for broke or just fit a better gasket and see what happens!! has anyone seen this before?
https://www.sau.com.au/forums/topic/274707-suss-piston/
Hey guys
If that's the inlet side, it looks like the beginning of a piston melting.
Have you looked at the gasket in the same position to see if it also has similar damage? Usually the stocko head gasket will let go if detonation has been an issue for some time and the piston can cop some damage from the detonation but not before the gasket blows.
https://www.sau.com.au/forums/topic/274707-suss-piston/#findComment-4656086
Righto, well it won't be a melted piston. Considering the damage on the gasket and the limited amount that can be seen on the piston, if it were my car, I'd be pulling the engine out and replacing or repairing it.
You could leave it if you wanted to but only the magical pixies know what damage could occur.
https://www.sau.com.au/forums/topic/274707-suss-piston/#findComment-4656140
has the motor recently been rebuilt? piston looks very/too clean? was the gasket the right size for the bores if it is overbored? did you use both of those alignment thingies that sit around the head bolts
personally I would pull it apart for sure. they may be able to save the piston with some light machining but you don't want it scraping up and down the bore looking like that.
https://www.sau.com.au/forums/topic/274707-suss-piston/#findComment-4656349
if you move the piston down the bore can you see any scores or marks ?
I would be pulling this engine appart regardless. I would dare say the rings are cracked as well.
The piston is very clean because this is a E85 engine :banana:
https://www.sau.com.au/forums/topic/274707-suss-piston/#findComment-4656363
she's all factory, so i'm sure the gasket was the right size.
cant see any scores on the bore at all, just a few water marks, it is cleaner than the rest, most likely the steam and un-burnt e85 cleaning it!
https://www.sau.com.au/forums/topic/274707-suss-piston/#findComment-4656432
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
