Change rim colour?
28 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
hey guys,
i was thinking of changing my rims colour. i currently have Yokohama AVS model 6's in 17" in white on a white car... similar to this car (but a r33):
I was thinking of changing the rim colour to silver, dark silver or chrome but im not sure if this will suit the car.
Silver
Dark Silver
Chrome
also wondering how much changing the colour will set me back and if anyone knows a good place in Melb?
Cheers
Edited by shaun123
https://www.sau.com.au/forums/topic/274712-what-do-you-guys-think/
Save money? Lol, i think dark silver, i have dark silver on my white car and it looks tops, dont get powder coat though, get them painted properly
And while ur at it take that spoiler off :thumbsup:
thats not his car...he said he has a white r33 with similar rims
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
