  • Replies 86
Put me down as a yes Cara.
Is there time time to dial in a bit more boost on the dyno? Or will it be strictly get your sheet and gtfo?
if there are any special requests let me know and im will dicuss with John Keen
Well I was interested, till I saw it was only 2WD - Boo to you Cara :banana:
there is an AWD class, even tho its a 2WD dyno.......................
I have spoken to John about having AWD cars there and he is happy to accomodate for them, by dropping the shaft
IF IT HELPS GUYS TROPHIES AND PRIZES UP FOR GRABS TOO!!!!!!!!! :thumbsup::)
i gotta book betsy to be tuned by keeny soon as ive put the new turbo on...i'll be definately keen....lets try and get more numbers than the one i did at classic performance last year!!!
excuse me. but my 34 is called betsy.
copy cat!!!!!!!!! :thumbsup:
will there be pos pulsar category. cant have u pitting me up against sr20 pulsars :thumbsup:
if i remember correctly the PGA dyno days have a "little battler" award for the car with the least amount of power output
last time some exa won it i think
so dan your in the running for that mate
how long have you had your betsy for????
3 years , 28th sept this year :thumbsup:
There is no dropping of shafts on the subaru Cara - won't be there sorry (well not to compete/partake anyway)
hmmm bugger that seriously sucks!!!!!!!!
will be good too see you there tho!!!!
^^ winner winner chiken dinner
guess that will come in handy for you krishy while im winning max hp in my n13 :P
Edited by Inline 6
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
