18/06/09 Baskin's Meet With A Twist Of Car Detailing!
  • Replies 294
which baskins Robins is this guys wouldn't mind checking other R34s on the meet
cheers
if there are THREE 34s there... i may well have to bring a change of pants... :bunny:
pfft 34s,
32 is where the legend began
they are faaar superior!
:P
...ok
unless its a 34 GTR Nur :laugh:
astro could never afford a Ztuned.. unless he cupped some major kahuna's at the casino!
ive done crazier shit for cash...
34s are teh secks!
can't wait to see this black one!!
gtfo newb!
:angry:
34s are teh secks!
Wooooooooooo
Yeah blacks a sick colour, ive changed my mind about the suss colours i was thinking about respraying mine (yes thats right Taz u were right). Think ill go for something with a bit more depth like a black.
Edited by Danski
pretty sure i also said that light blue wasn't the best colour choice :angry:
BRANDON! - post up that pic u sent me of the black 35GTR
its jizz-tastic
gtfo newb!
:angry:
I'll gtf your o in a minute boy :)
it's just simple fact - black silver and dark blue 34s are sex incarnate.
some colors just work well on certain shapes
33s - black and white
32s - gunmetal
35s - white and silver
simple facts bitch :D
I'll gtf your o in a minute boy :angry:
32s - gunmetal
simple facts bitch :)
ok ok deal (only cuz u said gunmetal 32s are the sex)
maybes move these epic chats to our other thread? lol
Yesh Madam.
http://www.gtrblog.com/2008/06/12/singapor...ts-matte-black/
http://852racing.com/Images/blog_03122009_...e_r35_gtr_1.jpg
http://images.google.com/imgres?imgurl=htt...sa%3DN%26um%3D1
(the orange 33 looks like something that came out from Tokyo Drift...)
But like I told you on msn, theres no words to describe seeing that in real life.
I think this has been posted somewhere in the r35 GTR thread some time ago.
Edited by Brandon
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
