Is the G25 no longer made? I picked one of these up for $250 from Hardly Normal 3 years ago. It's connected to my Microsim Race Base (showing my age here).
The shifter quality is still pretty plastic, but better than playing on a keyboard.
G25 isnt sold anymore, the second hand ones ive seen on Ebay have ended up sellin g for the same money as a G27....
380 on ebay seems the cheapest, but also has the biggest postage $80 from what i recall. it seem the cheaper the product. the more the postage is.
i bought my G27 from Umart in brissy. cost me $405. picked it up the next day. no waiting, and no overpriced postage.
some of those driving rigs are pretty nice. but far too expensive for a few bits of thin metal tubing. and a friend has the VR one......very flimsey, not good for 650 bucks. and 2000 forget about it. mine cost me $250 for the bucket seat about 8 yrs ago ;) all the rest was free!! (except the G27 obviously)
there are other driving games other than GT5 you can use your steering wheel with. no need for it to collect dust :D
The Racebase plans and hardware cost me something like$80 back in 2004, and probably $50 worth of MDF.
I see they're back in business, and you can get the plans for $9, and hardware for $50-ish. If you're handy with woodworking, they are pi$$ easy to make.
http://www.thewayiplay.com/mainforum/index.php?topic=894.0
too much of a pain to get in and out of though. if i was going to do it i''d leave 1 side off so you can slip into it easier, or make it have a scissor door, lol
What? Seriously?
Are you an arthritic 80 year old or something? Have you actually tried these things?
I can think of plenty of reasons one might not want one of these, but ease of access? Come on - surely you can do better.
Besides, the steering wheel tilts up out of the way if you want it to (although I've never had to do that)
Each to their own though.
you are pretty much sitting on the floor. i'd rather have it at seat height. i don't have the money or space for a sim anyway, so i'll just be sticking with the controller. never bothered me in the past. i might get one eventually (when i'm in a house with more space), but that won't be for a while yet.
i'd really like to get a car and mount one in the car so the steering wheel, etc is all in the exact location it would be in real life.
looks good, and cheap, and real easy to make. would save alot of stuffing around with measurements like i did. ill stick with my alloy one tho. Sure its pretty well on the ground, and doesnt look as artsy. but its sturdy enough to use it to drag yourself out if need be. Easier to get out of than a bean bag :dry:
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
