Waited for So long and no God dam R34 GTT..... :)
that decision would not have been made lightly.. although it would be cool to have it, i dont think many people would use it in comparison to how many would just use the gtr. i still think theres hope for any cars people think have been overlooked, no reason why they cant make it DLC in the future if they get enough demand for it.
still, surely they could have sacrificed one of the 25 mx-5's for it lol.
and WTF is with having 25 mx-5's?! are most gran turismo fans middle age having a mid life crisis and balding or something?? are they hairdressers?? are they gay?? can someone explain?
Edited by jonboy
Well people who owned an R34 RWD or who want to know how an R34 RWD is for testing purposes could use the car in GT5... But as u said stupid bloody MX5's just filled up the list... I Sooo wanted to buy an R34 GTT in the game and modify it... Considering the game has real specs with the cars in real.. Each mod would have shown how much can the car gain in performance and handling
My Dreams are shattered... Stupid ****** Polyphony!!!
Whats the difference between the versions other than price..? What price are each and where is the cheapest place to buy..?
The collectors edition comes with a few extra cars. the signature edition comes with more cars again plus a booklet, model and some other things as well. Pretty sure i have the editions in the right order.
Anyone with a real version of the car wanting to know how much of a gain they will get from mods shouldn't use any of the gt games, or any game for that matter, as a guide to how much power they will gain. the power gains from mods in the game are not accurate. they may have used the stock specs but the aftermarket specs are not realistic.
LOL errrr nope
Standard and premium cars. The premium models have interiors, and the exteriors are a lot higher quality and I think more advanced damaging on the car. Standard cars don't have interiors and their damage is limited to scratches and dust. I think thats it.
So now im looking for a new HDD. What brand is the best option and what size is the go..? Cheers
any brand will do, Seagate, Western Digital, Samsung etc as long as its a SATA drive (serial ATA) 2.5". same size as laptops use. get the biggest capacity within your budget.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
