yeah the photo thing is awesome, got my old school Kombi, dumped, gloss black with a big ass exhaust.....will post when i can. some of the filter options etc are really cool too.
im still waiting for my 400R, how much was it if you can remember?
i never seem to have more than 200k credits.....every time im in the used car lot i find something else thats old or just dam cool. 70 cars and counting (got the 50 car trophy in less than 24 hrs)
Jon, what cooling do you use for your PS3?
I just sit a pedestal fan in front of it and angle it to the lower front of the console (40GB version).
Doesn't even turn it's thermal fan on (sits in a poorly ventilated tv cabinet).
i haven't used any cooling so far. it ran sweet for 3 years (bought on release day) it sat in a closed cabinet with no venting for about a year. the first time i fixed it there was heaps of dust clogging up the inside so i cleaned it all out real good. the last couple times have been minimal dust build up, yet it's still happened. i've just pulled it all apart and fixed it again today and i ordered one of those usb fans that force more cold air in. has anyone used these and seen a lack of failures or anything?
on the 40gb one there is a auto dest blow out function... i've used it once... just turns the fan on full speed in an attempt to blow out crap. I've noticed my ps3 is running warmer than usual... i'll do that again soon and maybe look at a cooling option if needed.
You activate it by holding down the eject button and turn it on from the main power switch at the rear
i did the final top gear challenge last night. took me about 10 attempts to finally complete 2 laps. the first time i got DQ'd at (i think) the follow through (right hand corner before the tyres and back straight). i ran over the painted lines (going so slow you don't even think about it because the faster cars understeer a bit as you turn in so you are ok). second attempt i got to the first corner on the second lap and got taken out by one of the cars coming the other way and DQ'd (since there is a group of cars that is lapping half a lap ahead). 1 or 2 other attempts i made the same mistake at the follow through. i think one i cut the corner on the start straight a little bit (may have even been overtaking a car and got rammed off, can't remember).
but finally i managed to complete 2 laps without being DQ'd to complete the event. got gold (extremely easy to do). even silver is easy. i was into 3rd place after the first lap. 2nd by halfway through the 2nd lap and into first at the end of the back straight. you have bronze after about chicago on the first lap though. the car in 7th gets taken out on the first corner, then on the braking into the chase you can getinto 6th and the car in 5th gets taken out, or runs wide into chicago as well, so by the time you get to the hammer head you have the bronze.
I'm struggling on the 2nd topgear challenge... that lotus is horrible, and the AI of the other cars is fkd
any tips?
If you simple want to pass then just take your time and simply overtake under brakes. remember you have 2 laps to do it. don't try and overtake everyone in the first lap
yea the lotus challenge was tricky, but yeah mads onto it. eventually you'll get to learn what pace you need to be at. if i remember correctly i think i was in 3rd place going into the 2nd lap and took 1st going around hammerhead. unless theres an AI car in front i still have a hard time finding gambon after that long straight, just cant see shit lol maybe i need a bigger tv?
and while doing the karting challenge are you guys looking out for banana peels and turtle-shell missiles? or is it just me..
well it was just you, but i'm sure i will now. i actually like the go-kart challenge. it's a bit of a pain that there's no go-kart races in the A-spec section.
haha, yeah I ordered one last week so should have it any day now, hope it makes a difference (can't see why t wouldn't).
My PS3 has only started using the exhaust fan with Borderlands and GT5, not one of my other games seem to heat it up to the same extent (even with the cabinet door closed)
theres always online. nextgg organised a race for tonight.
http://www.nextgg.com/forum/viewtopic.php?f=101&t=7140
i'll be joining if i can remember
yeah i'm too lazy (and disorganised) to race in online races like that one
i heard it was cos your a shit driver and wanted to save yourself the embarrassment. anyway, turns out i wont be there tonight. fuckin RL messin with my gaming time.
So when does the top gear track become selectable for practice &/or online races???
Get gold in the top gear combi race. I have heard people have got it for finishing bronze on the lotus race as well, but I dont know that for sure.
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
