Has anyone seen this new game coming out soon.
Its called need for speed underground and it comes out on xbox, ps2, pc. Its about illegal streetracing where you can customize up to 20 import vehicles, and when i mean customize i mean everything on the car can be changed.
Check out this website www.needforspeed.com
:burnout:
https://www.sau.com.au/forums/topic/27495-nfs-underground-video-game/
Yeah this game does look pretty insane
its sponsored by hks and g-reddy also kenwood is sponsoring it and you can do your own customer stereo installs
how cool is that
already got mine on order hahaha
should be sweet
have youdownloaded the trailer for it? loook awesome!
Originally posted by sewid
ive been waiting a while for this game. I have not seen any evidence to say that there will be Skylines in it.
They mostly mention Toyota Supras, Celicas, some Hondas...
I saw a screen shot of a 350Z, so if they have Nissan cars in it, one would assume that they would have a Skyline.
I mean how can you not have the best car Japan ever produced in the Game?
yep i defintely can't wait for need for rice :) ... think about it .. the more rice u got on the car the faster it goes .. put blue led washers on and u get an instant boost increase and an extra 100 hp shot of NOS :) ... and get out the motec sound system ... :) .. i think if u play enough u might get the car to fly .. hehehe ;) ... dont' expect this game to be any good ... the need for speed series is are some of the worse games ever made .. i can't beleive they sell so many ...
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
