hi I have The following for sale all parts are off a 94 r32 gtr, in glen waverley vic but Iam willing to post
2 x afms $125
2 x cam shafts $100
1 x ecu $50
2 x m's pod filters with m's adapters $50
6 x 440cc injectors cleaned and flow tested $150
1 x fuel rail with fuel pressure regulator $50
1 x front pipe $20
2 x dump pipe's $20
5 x bridgestone semi slicks 16/225/r50 70 to 80 % meat left $50 each
2 x cam gears $40
All prices are negotiable as I dont really know what this stuff is worth so just make an offer if you want. Pm me or give me a buzz on 0449587603. If you need pics let me know but Iam pretty sure everyone knows what this stuff looks like. thanks den
https://www.sau.com.au/forums/topic/274973-r32-gtr-parts/
2 x afms $125 SOLD
2 x cam shafts $100
1 x ecu $50 SOLD
2 x m's pod filters with m's adapters $50 SOLD
6 x 440cc injectors cleaned and flow tested $150 SOLD
1 x fuel rail with fuel pressure regulator $50 SOLD
1 x front pipe $20
2 x dump pipe's $20
5 x bridgestone semi slicks 16/225/r50 70 to 80 % meat left $50 each SOLD
2 x cam gears $40
https://www.sau.com.au/forums/topic/274973-r32-gtr-parts/#findComment-4667251
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
