  • Replies 443
Put me down Cara I'll be there.
4WD I spose - but I'l just remove the fuse when I get there lol :D
edit: Just noticed I am already on the list lol -
Edited by Weezy
as per Shane's request I've stickied this topic so any dribble in here will be deleted guys
thanks Pete!
you goose :P
Where is it?
When is it?
and how much?
i'm running in my rebuilt RB26 atm, still got 800kms to go.
just wondering whether i will have the kms done on it before the day.
cheers!
All your questions can be answered by taking a quick scroll up and check out the flyer in post #1.
Quick question...
Are you having limits on entry into a particular class?
With only 20 spots you would want a bit of variety.....
Im still keen on entering the VY SS Ute. I know that my Line will get flogged and Im just not ready for that. Haha
Quick question...
Enter the Skyline - you can compete with Cara for the N/A 6 Cylinder class! If you dont enter I dont think she has any competition for that trophy lol
I'm keen. My GTR is only driving the rear wheels atm and also feels ~200rwkW instead of ~350rwkW. Hope fully I'll have it all sussed by 15 August in time for Mallala on the 25th.
Do R32 GTRs have to pay the extra $ considering we can just remove the fuse prior to the event and there is no need to drop the front driveshaft?
Edited by writeoff
Dude I am IN for the WIN, how do I become a member???? What do I get when I do?
Hey Ahmed.....I assume you're referring to the SAU-SA club?
If so, PM Ruby your email addy and he'll hook you up with the appropriate form.
1) Cara - R34
2) Kye - R33
3) Vu - R33
4) Ruby - R33
5) Krishy - R33
6) Craig - R34
7) Wayne - R32
8) Lee - R33
9) Adrian - R33
10) Ben - R31
11) Chad - R32
12) David - R32
13) Admed - R33
14) Anthony - R32
15)
16)
17)
18)
19)
20)
Quick question...
dont know if u actually saw that there is a 6 cylinder naturally aspirated class there penny :laugh:
no just remove the fuse and youll be right.
put my name down for this.
done :blink:
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
