hey guys and girls
im pulling down my r33 gtst s1 manual and wanna get rid of as much of the stuff in my garage.
standard catback exhaust with cat...$70
3-3.5" catback exhaust with cat...$150
standard airbox with no snorkel...$50
standard smic...$50
pretty much the whole interior, standard seats, steering wheel, door inserts ect ect.
let me know what you want of it and ill see what i can do.
pm me with questions or offers, more pics too come.
located south east melbourne
cheers
Gezza
https://www.sau.com.au/forums/topic/275331-random-r33-gtst-parts/
  • Replies 41
hey mate,
You have gauge holder for the dash and gauges?
Yay my first post since i joined... heheheheh
hey mate, congrats on your first post and joining up :P .
wasnt exactly sure if you ment the actual instrument cluster or extra gauges and such, i cant pm you yet but give me a call sometime and ill c what i can do to help.
my number is 0433971544 btw guys, send a txt through and ill call you back asap.
cheers
Gezza
Edited by alwaysdreaming
airbag or non airbag steering wheel?
hey Musky, non airbag steering wheel.
as for the cat bloodsword, its a redback cat i have no idea if its any good it just came with it when i got it.
yeah i could seperate it, send me a txt and ill send you through a picture or two.
my number is 0433971544 for anyone wanting to get in contact with me.
cheers
Gezza
hey guys i also have a series 2 spoiler with brake light in black.....$100
i really wanna get rid of my main interior parts aswell, like rear seats, front seats ect, throw me some offers.
give me a call or txt on 0433971544
cheers
Gezza
hey guys
my internet is broken at the moment so sorry if i haven't gotten back to you, am using my mates computer at the moment.
if there is anything your after you'll have to text me or call me on 0433971544
thanks
Gezza
  • 1 month later...
hey guys
internet back up and still got lots of stuff.
rear seats-$70
center console-$50
gear stick surround (leather is shit)-$20
rear arm rest things-$40
Series 2 black spoiler-$80
series 1 front bar (black spray paint)-$80
standard non airbag steering wheel-$40
can get more photos if you want. just txt me on 0433971544 and ill mms you.
cheers
Gezza
Hey man, do u have plastic that goes around drivers side door handle inside? Keen if so. mines a s2, do u know if they same?
hey mate
i do have one, not sure if s1 and s2 are the same though. PM me your phone number and ill send you some pics and you could have a look?
or maybe some1 on here could help out.
cheers
Gezza
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
