  • Replies 40
Posted Images
Thats been for sale for quite awhile...... I wonder why it hasnt sold.
Someone had too much time on their hand.
But hey its currently at $2.5k - spray it matte black, rebuild the engine and got a somewhat cheap-ish R32 track car.
https://www.sau.com.au/forums/topic/275344-what-the-hell/#findComment-4665213
did the head gasket get attacked by barney :D
repray idea aint half bad, id daily it matt black :P didnt see it mention na or turbo
lols to below guess i didnt read that much into it. then again wouldnt be the 1st car i see without turbz with a fmic
Edited by Inline 6
https://www.sau.com.au/forums/topic/275344-what-the-hell/#findComment-4665260
yeah, if i had the cash I'd buy it :D chuck in a 26/30, use it as a 'shit my pants' track car
-D
https://www.sau.com.au/forums/topic/275344-what-the-hell/#findComment-4665355
would look like a can aswell, could get 10c from the depo these days for it
Or maybe you could cut it into several pieces and get more?
that is until you take the shrapnel down to the depot and the dude is like, is that a headlight switch in that can?
You could always try Sims.
https://www.sau.com.au/forums/topic/275344-what-the-hell/#findComment-4665374
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
