Item:
Nissan Skyline R32 GTS-4 Coupe
logan, qld
Website:
this
Item Condition:
lots of good parts
Reason for Selling:
not needed
Price and Payment Conditions:
bootlid with spoiler - $140
rear bumper - $50
tail lights - $150
front seats pair - $150
rear seats - $100
dash with air vents (all in MINT condition) - $300
headlight and wiper stalks - $60
clutch and brake pedal (perfect for manual conversion) with clutch master cylinder - $200
digital climate control - $50
drivers window switch - $50
passenger window switch - $30
lh door complete (with window switch, glass, trims etc) - $100
lh rear quarter glass -$50
5 stud conversion (front and rear calipers, discs, handbrake cables) - $950
RB20DET complete with AWD gearbox (turbo, all mounts, harness etc) - $2200
Intercooler piping to suit RB20DET - $100
17x8, 5x114.3 chrome wheels with tyres 60% tread - $700
Damper adjustable supension - $300 (rhr is bent)
Full exhaust 3" dump pipe to cannon muffler with hi flow cat - $350
HEAPS OF PARTS - if you need something, ASK as I may have it
Extra Info:
ALL PRICES ARE ONO
Pictures:
will be up over the weekend
Contact Details:
PM or Call/SMS 0401 121 962
https://www.sau.com.au/forums/topic/275477-parting-out-r32-gts-4-coupe/
  • Replies 41
Posted Images
Jimmy - I have headlights from a 32 4 door so yes, have headlights
TRB001 - pics will be up tonight of rims
jonn - diffs will be sold complete - will work out pricing for you once removed
Steve - I've got 2 exhaust for 32, one complete, one needs dump pipe. both hi flow cats, one has cannon exit, other has twin hotdogs.
ALL PICS TO BE POSTED TONIGHT
true true, id want the one with cannon, but dont need a dump pipe. just msg me on msn or send me a pic via pm if u can bro. thanks
UPDATED PARTS LISTINGS AND PICTURES
lots of good parts
Reason for Selling:
not needed
rear bumper - $50
tail lights - $150
rear seats - $100
17x8, 5x114.3 chrome wheels with tyres 60% tread (toyo teo plus 235/45r17) - $800
Interior trims from $10 - just ask what you need, will let you know
White handbrake boot - $30
splitfire boost gauge - $30
steering wheel - $100 (has been retrimmed, but MINT condition)
Pictures:
dash and window switches
rims
bumper, boot lid, taillights
taillights
rim close up
tread left on tyres
handbrake trim
steering wheel
steering wheel
steering wheel
boost gauge
sunroof and roof trims
dash
Any chance that you have the accelerator cable and is the Gear stick rubber boots in good cond, no cracks in the rubber?
How much posted to Brisbane 4055?
im located at 4133 - so pick up is available saves postage
accel cable - $40
gear stick rubber boot ?? are you talking the one that sits around the top of gearbox, shifter into top of gearbox??
or the cover around hole for shifter to come through tunnel?
Im gonna need it posted, have no licence atm :)
I want the one thats bolted to the tunnel with the 4 10mm screws and the one thats under that, which attaches to the gearbox itself. Aslong as they have no cracks or splits ill take em and them and accelerator cable to.
I dont need the trim bit that clips into the centre console.
OHASIF - will let you know about the gearbox tunnel trim and accel cable PM and pics tomorrow night
MissR32 - not seperating vents from dash as yet, anyone wanting to buy just vents, JJR sell them individually
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
