Item:
Nissan Skyline R32 GTS-4 Coupe
logan, qld
Website:
this
Item Condition:
lots of good parts
Reason for Selling:
not needed
Price and Payment Conditions:
bootlid with spoiler - $140
rear bumper - $50
tail lights - $150
front seats pair - $150
rear seats - $100
dash with air vents (all in MINT condition) - $300
headlight and wiper stalks - $60
clutch and brake pedal (perfect for manual conversion) with clutch master cylinder - $200
digital climate control - $50
drivers window switch - $50
passenger window switch - $30
lh door complete (with window switch, glass, trims etc) - $100
lh rear quarter glass -$50
5 stud conversion (front and rear calipers, discs, handbrake cables) - $950
RB20DET complete with AWD gearbox (turbo, all mounts, harness etc) - $2200
Intercooler piping to suit RB20DET - $100
17x8, 5x114.3 chrome wheels with tyres 60% tread - $700
Damper adjustable supension - $300 (rhr is bent)
Full exhaust 3" dump pipe to cannon muffler with hi flow cat - $350
HEAPS OF PARTS - if you need something, ASK as I may have it
Extra Info:
ALL PRICES ARE ONO
Pictures:
will be up over the weekend
Contact Details:
PM or Call/SMS 0401 121 962
https://www.sau.com.au/forums/topic/275477-parting-out-r32-gts-4-coupe/
  • Replies 41
Posted Images
Jimmy - I have headlights from a 32 4 door so yes, have headlights
TRB001 - pics will be up tonight of rims
jonn - diffs will be sold complete - will work out pricing for you once removed
Steve - I've got 2 exhaust for 32, one complete, one needs dump pipe. both hi flow cats, one has cannon exit, other has twin hotdogs.
ALL PICS TO BE POSTED TONIGHT
true true, id want the one with cannon, but dont need a dump pipe. just msg me on msn or send me a pic via pm if u can bro. thanks
UPDATED PARTS LISTINGS AND PICTURES
lots of good parts
Reason for Selling:
not needed
rear bumper - $50
tail lights - $150
rear seats - $100
17x8, 5x114.3 chrome wheels with tyres 60% tread (toyo teo plus 235/45r17) - $800
Interior trims from $10 - just ask what you need, will let you know
White handbrake boot - $30
splitfire boost gauge - $30
steering wheel - $100 (has been retrimmed, but MINT condition)
Pictures:
dash and window switches
rims
bumper, boot lid, taillights
taillights
rim close up
tread left on tyres
handbrake trim
steering wheel
steering wheel
steering wheel
boost gauge
sunroof and roof trims
dash
Any chance that you have the accelerator cable and is the Gear stick rubber boots in good cond, no cracks in the rubber?
How much posted to Brisbane 4055?
im located at 4133 - so pick up is available saves postage
accel cable - $40
gear stick rubber boot ?? are you talking the one that sits around the top of gearbox, shifter into top of gearbox??
or the cover around hole for shifter to come through tunnel?
Im gonna need it posted, have no licence atm :)
I want the one thats bolted to the tunnel with the 4 10mm screws and the one thats under that, which attaches to the gearbox itself. Aslong as they have no cracks or splits ill take em and them and accelerator cable to.
I dont need the trim bit that clips into the centre console.
OHASIF - will let you know about the gearbox tunnel trim and accel cable PM and pics tomorrow night
MissR32 - not seperating vents from dash as yet, anyone wanting to buy just vents, JJR sell them individually
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
