  • Replies 48
Wrecking a R33 series 1.
Passenger seat with rail $150
Boot lid wtih hinges $100
interior $150 lot
Dash $150
boss kit $80
rear seat $100
whole door with glass and trim $150 each
front disk $100 pair
Blistein Suspension strut and spring $450 set
rear diff $300
Front mount cooler $150
aircon setup$150
rear bumper $100
Fix bucket no rails $150
seat belt $30 each
just ask what you want and i'll see if i still have it....
thanks
Melbourne Eastern suburbs
hey mate . the passenger side mirror still avaliable for sale?will da s1 mirror suit s2?
Whats the condition of the headlights and how much?
also you still have the cover in the driver side panel (bottom right of steering wheel looks like fuse box cover) and how much?
aaaaannnddd whats the condition of tail lights and how much?
interior $150 lot
Dash $150
boss kit $80
rear seat $100
rear diff $300
aircon setup$150
rear bumper $100
seat belt $30 each
thanks
hey mate just wondering if u have the power window control box for the driver side still
Hi got the exhaust tip? std or a little quite one? got a 4" on mine n its buggin the living shyt out of me every morning when the neighbours come out and chuck a fit about it.
Hi mate,....i only have the original R33 muffler...$130 ono
  • 2 months later...
Hi,
Interested in the boss kit..
Is it a 'basic' one that doesn't have HICAS, or a proper HICAS one?
How much posted to Gold Coast QLD 4212?
[/quot
Boss kit= basic one with out hicas..$55 posted
moulding between quater and front door...$25 posted.
