Hi, Im looking to upgrade injectors for my r33 which will need to get me to 300kw, now im left to choose from s15 injectors, a set of aftermarket new 550cc injectors or hi flowing mine. What do you guys think is the best option and what have you had experience with and where can I find the best prices to get some, thanks.
https://www.sau.com.au/forums/topic/275709-rb25det-r33-injector-upgrade/
The best option is to read.
Hi-flows are super well documented
S15's - same deal
And as for new ones... there have been half a dozen threads in the last month in 550's (and also 740's).
End of the day, it comes down to budget. If you want it done on the cheap - 2nd hand/hi-flows. If you want unquestionable reliability you buy new.
Simple.
just been through this and will help making a mistake. just go the nismo 555. not saying that the s15 injectors are bad but had strips torn of me by my tuner for buying them. they are a pig to tune and and will not be as good as the aftermarket injector. mine have been flowed out to 600cc. he said that they have to be tuned as a 480 at the bottom and a 600 at the top of the maps.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
