I've noticed two strange noises coming from the 26 so i just wanted to know what are your thoughts.
The first happens when i give it a quick rev to about 2000rpm as soon as i let go an it starts to drop off u hear like noisy tappets sort of noise from the head (clack clack clack very quickly) and it stops even before it reaches back to idle.
Its the kind of noise you'd get from using thin oil but i'm using Redline 20w50, with absolutely no strange noises on cold starts or idling otherwise.
Oil pressure is good also - 88psi cold and 24psi hot at idle.
It just doesn't seem normal.
The second happens only when the car warms up. It's the kind of noise u get when u over tighten a timing belt, but i'm not sure if its coming from the timing belt area.
It sounds like its coming from the exhaust valve cover around the no.2 area, so i took it off and everything looked ok.... ie. no scratch marks on the cam lobes and everything looked lubed up.
Not sure if my mind is playing games on me but its hard to pin point this one.
Is there any thing that can be bad, or going bad to make this sort of groaning noise?
As i said....only happens when the car is warmed up.
When i bought the engine from the importers it already had the water pump and timing belt changed, i dont know if the tensioner and idler pullies were changed and i don't know the milage on the engine (R33)
Thanks.
https://www.sau.com.au/forums/topic/275814-strange-noises-from-26/
Try recording the sound and post it on youtube or somthing, since its hard to describe a sound in words.
Also, why 20w50? is this for track or street? Nissan's specification is 7.5w30 or somthing for street.
Thanks.
Try checking the turbo's wastegate actuator
The noise you get from revving to 2000 quickly and backing off might not be the best and is usually associated with bearings as it occurs when you snap the throttle shut.
Your thicker oil could contribute to it - when you rev the engine the oil that moves to the head may not be able to get back to the bearings in time as its too thick... Just a guess.
The timing belt noise is hard to say - have you tried listening to the cam cover using a screwdriver to get a better idea of where the noise is coming from?
it's injectors. what happens is when you rev they are running. as you quickly step off the throttle for a split second they all shut and are quiet for a moment, then as the revs fall and return to idle they start again. GTR 440cc injectors are very noisy. I have to lol at the number of people who have told me they have noisy tappets etc when it was just normal RB26 injector noise. tappa tappa tappa.
i have no idea what the second noise is. get it checked out. but without hearing the car, what you described first is the injectors.
yep they are noisy at idle too. the only time the noise will stop (if it's injector noise) is that brief moment when you rev the engine up to say 3,000rpm then quickly get off the throttle. as soon as you get off the throttle the noise will stop for a second as the revs fall, then start again as it hits idle rpm. so if it's not making this noise at idle, the sadly it's most likely something else. GTR injectors are very noisy though and that noise is often mistaken for other things by those not used to what RB26 sounds like.
When my old man had his R34 GTR we had a concern over a noisy tappet type sound but was told by multiple workshops it was just the solid lifters that the GTR has but GTS-T's don't, and that it was completely normal.
I must say the RB26 even in R34 guise did not seem to be a particularly refined engine but all is forgiven when the driving experience is considered.
Edited by Swink33
most these rb's have done a fair few km's 20w-50 wont be the issue. i would not run 7.5w-30 in any gtr other than a new engine. 10w-40 at the least.
i reckon the noise in this case will be the injectors like beer baron has posted, we get countless gtr owners complaining with the same issue.
I thought he said the noise only came on decel, then went away at idle.
"The first happens when i give it a quick rev to about 2000rpm as soon as i let go an it starts to drop off u hear like noisy tappets sort of noise from the head (clack clack clack very quickly) and it stops even before it reaches back to idle."
Injectors are going to be noisy at idle, not on decel.
well its definitely not the injectors.
When listening i could hear the injectors operating on idle, and when revved quickly, on decel u could here when they cut out 4 a split second and then come back on, but that is not the noise i am talking about
It comes from the cam covers for sure.
Like i said "noisy tappets" kinda noise
Just sounds strange as the 25 never did it
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
