This is from the metal cat site, so its hardly unbiased, but its a start.
"This especially holds true to the Magic , 'Xforce' and other 'new brands that continually enter the market under aspiring 'New Name Brand' companies. Why not as an exercise call them and ask them to fax you through their EPA/CARB/Euro test results from manufacturing factory?
UPDATE : Credit to Xforce , they have now deemed their cat ‘For Race Use Only’ . "
my r33 had a melted and collapsed metal cat. had only done about 10000k's with the cat in there.
Made the car run really badly and wouldnt boost at all. took me ages to find out it was the cat...
  TALBO said:
What exactly is wrong with ceramic cats?
I think there are limitations with what you can do with the material - they have to run finer air low passages and therefore flow less. If you look at the 200 cell metal substrate cats the holes that the air flows through are relatively big. On the ceramic i've seen the holes look like pinholes. I'd guess ceramic it too brittle to be made as thin as metal.
my cat got filled up with shit (thinking due to a rich running motor not allowing it to work properly), then kinda melted back towards the back half of the shell, hence me having to bash it out. Dunno if it was a highflow or what, but I'm sceptical about buying another one cause I don't want to be replacing them on a regular basis!
this topic confirms what I was told.. if you have a high powered RB - and especially do track days - then there is no
good cat solution and when they go bad it might not be immediately obvious they have gone bad.
basically none of them can withstand sustained blasts of 800 degree exhaust for long.
Absolutely nothing.
As long as the cat decent quality and well made, and is suitable for the level of tune of the car in question, they are fine.
They may not be suitable for heavily modified or heavily fueled cars - For applications like this you would probably want to look towards a metal cat (ie Catco)
    • You're not the first person that's said that about this car lol. A Touring wagon GT in Spark yellow mica would be the dog's danglies 😆 I will keep an eye out for a future purchase for sure. The seats are almost like the OEM Recaros... electric adjustment for fore/aft and tilt movements except reclining.
    • Yes!! I love these! It's a shame its not the wagon though!   Thank everything that's holy that it doesn't have the interior of the Aussie delivered ones. Those seats are so much nicer.
    • I'm both sorry and thankful that you do that.
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 🙂 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
