umm just a look out peeps for a silver..possibly light blue or grey skyline....R31 with p plates and rego number starting with WWG***....This moron decided it would be cool to do some street drifting and managed to side swipe a white toyota hilux out the front of Direct Mix Concrete on Roxburgh avenue, Lonsdale this afternoon...The major problem being, He drove off straight away..Mate, if your on here, The police have your number plate and youve gotten yourself into more trouble by doing a hit and run....Come forward to the police and fess up so people like me that have similar cars in the lonsdale area dont get blamed first...
Thankyou
https://www.sau.com.au/forums/topic/276417-hit-and-run-skyline/
lolz i had a tosser up my rear at glenelg once, thinking to myself might be a undercover cop i just made sure i drove extra safe n slow.
come to the round about turning right, he overtakes on outside and proceeds to hang it sideways. trouble is he went a bit too far out and to my call of "he's lost it" swung it back the other way and slamed into the parked cars. i went to pull over make sure he was ok and the dude just guns it off, so i went back later to suss the damage.
cops were there looking like a slight dent in 88 magna bumper bout $10 damage, about 10 witnesses that got his plate. so instead of fessing up paying for some cheap ass bumper he got police report saying drifting like a tool, hit and run :P justice served
i was down the bay on jetty road one rainy sat night with the missus when a guy in a white vr wagon did the same thing...got it spinning on the tram tracks and then lost it into parked cars out front of royal copenhagen then took off dragging half his front end on the road
Damn Bogans
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
