Hey all ............
i need a little help my R33 Gts-t auto
after i gave it a little bit of a hard time on wednesday night
it has started slipping
1st gear dont slip nor does 2nd that i can noitice
and i dont think 3rd does either
but once in 4th-O/D is slips like nothen else
Could really use some help becasue its only started slipping afteri over headed it down the 1/4
thanks in advance
Andrew
https://www.sau.com.au/forums/topic/276659-auto-gearbox-is-slipping/
what im worried about seen its done this ..... how long does it how until it shits it self ........ becasue im looking at upping the boost this week
You're not going to have a catastrophic failure, she'll just slip like mad until the band gives way completely then you be missing that gear.
If I were you, I'd leave the boost as is and baby her until you sort the issue.
Either drop the manual in or replace the box with a second hand one for now, depending on your financial situation.
My clutch pack fried too, and I found a secondhand auto box for $350, pulled the old one out, chucked the replacement one in, and turfed the old box.
Awesome thing about everyone converting to manual is that complete boxes are cheap as chips.
picked up a 2nd hand auto box for 150 end of last year after i killed my old one. much cheaper to just buy another box and swap it rather than pay for rebuilds etc
also look into a shift kit and trans cooler, or you'll just kill the next one
Edited by stenve
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
