hey all, Nigel from adelaide here.
Im in manly for work for the next few days. I got here 2 hours ago, and im bored already.
Anything going down in manly?
Lol, nothing going on in Manly lately, 2 weeks ago was the food and wine festival and besides that nothing hahaha, venture around the northern beaches!
https://www.sau.com.au/forums/topic/276799-stuck-in-manly/#findComment-4683657
two words
the steyne
.. showing my inner bogan right now lol
HAHAHAHAHAHAHAHAHAHA!! Steyne!! Lol.... Go to the shark bar(New brighton Hotel) if you want some drinks at the moment, otherwise tonight, shore club (Beach front, on the opposite side on the steyne if your looking down the corso) has a fair few people going there on sunday. Theres also wharf bar (Where the ferries are) besides that, it's too late to do anything now besides drink and what better thing to do!
https://www.sau.com.au/forums/topic/276799-stuck-in-manly/#findComment-4683676
sorry, i should have stated, i have no problem finding a place to drink, I have plenty here, and im well aware of the good drinking places haha!
i was just looking for some entertainment or something to do
https://www.sau.com.au/forums/topic/276799-stuck-in-manly/#findComment-4683685
Head to Warringah Mall, go see a movie or do some shopping at coles or woolworths haha. Go for a walk along the corso to cold rock and get some ice cream? Drive out to narrabeen/terry hills and go to the driving range/chip and putt? Lots to do if you have a car!
https://www.sau.com.au/forums/topic/276799-stuck-in-manly/#findComment-4683858
no car, only foot and taxis
https://www.sau.com.au/forums/topic/276799-stuck-in-manly/#findComment-4683889
im glad im simple... simple things amuse simple people.. i can find something fun to do anywhere.. just gotta look.
a friend of mine, Dean Tyler (otherwise known as Soquete) instructs a capoeira class in manly, Sinha Bahia de Capoeira... its at mona vale. check out www.capoeira.cc if your interested... if not, stop being a spoil sport and get out and find something to do..
theres also a little cafe in avalon thats got a couple of drifters there... usually see a tidy ae86 and looks like an older bluebird.. might be able to strike up something to do with them. its across the road from subway in the main st
https://www.sau.com.au/forums/topic/276799-stuck-in-manly/#findComment-4685002
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
