Hey guys i'm looking at buying an R34 GTT but I want to get a specific looking one. I don't know what it's called/what year it is... but I don't want the ones that have the silver 'S' symbol on the hood or the red 'S' symbol in the front grille area of the front of the body. It's the one that's sort of plain at the front... like the R34 in the pic below. Could someone tell me what make/year this type of R34 GTT is? Thanks guys
Edited by DaveR34
https://www.sau.com.au/forums/topic/276857-r34-gtt-body/
theres no specific type of r34 that is what you are describing.
red S's are apart of a cosmetic kit. mostly the NISMO kits.
where as the Silver S is apart of all r34s that come from the factory and are only removed by private owners. so when you buy a r34 you just need to see if they have already taken it off. its not hard to do urself either.
basically any r34 from 1998 to 2001 can be wat you want. you just have to make sure its not kitted with the things you dont need.
https://www.sau.com.au/forums/topic/276857-r34-gtt-body/#findComment-4684332
series 1 1998-2000 comes with a "S" n the bonnet, Series 2 2000+ comes with a "S" in the grill and as above the red "S" is a nismo one. my series 2 one was pretty easy to remove and i could put it back in if i wanted. series one im guessing of you take it off wrong you will need to repair the paint a bit.
https://www.sau.com.au/forums/topic/276857-r34-gtt-body/#findComment-4684599
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
