Hey all I just purchased a drift high flow air filter today for me r33
and it says that its cleanable and reuseable and that it can be used either wet or dry
so does this mean that when I clean it I don't have to use the oil from the cleaning kit
that came with it, sorry if this is a dumb question I'm a little new to this
my old laser tx3 was'nt worth modding lol everytime I tried people kept flogging stuff
off it, so now got skyline I'm starting to mod again.
mods to my car are coming along slowly
have got 3inch mandrel bent exhaust from turbo back
and now have just got air filter it is a lot more responsive and
I have plans to boost it up to 10 or 12 psi a little later on
https://www.sau.com.au/forums/topic/277009-air-filters/
Haha - welcome to the modding department!
You'll pick up from 'search' buttons that there are threads out there 'linked' to studies of using wet or dry filters.
Essentially these studies give ratings on...
i) quality of filtering and...
ii) quantity of flow
APEXi & K&N scored very well indeed on both + a couple of others in tests
For instance, HKS 'wet' sponge pods scored poorly on both areas, so I changed my filters but kept the induction pipes.
Then there's the question about whether or not you should use wet or dry depending on if you have AFMs.
To keep the story short,
It has been recommended that if you have AFMs, it's safer to keep your filters 'dry'. But many SAUers remain very careful = extremely careful about how they oil their filters whilst having AFMs. AFMs will not cope with residual/XS oil slipping past the filter. APEXi is an example of 'dry' type.
If you don't have AFMs (which I don't whilst using an F-Con Pro-V ECU), a K&N filter is an example of a 'wet' type.
You choose...
https://www.sau.com.au/forums/topic/277009-air-filters/#findComment-4686639
I'm kind of curious about how I would clean my APEXi Power intake (given that I live in a dusty place and it cost me $160), in the test that one of the 4cyl mags did, a cheapo brand called 3A Racing came out on top in terms of the trade off between filtration and flow. I'd try and use a dry filter, it's a pain in the ass to be cleaning and then trying to oil a K&N filter enough to actually work but not enough to kill the AFM.
https://www.sau.com.au/forums/topic/277009-air-filters/#findComment-4687235
Take it off and blow it out from the inside out.
Could clean it with regular filter cleaners too. Then dry it and put back on. Done
https://www.sau.com.au/forums/topic/277009-air-filters/#findComment-4688742
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
