Just put an air shifted g-force box in it..at least you can still say its manual and you wont have to worry about sorting out converters..
what about picking up the milk and bread though...you cant down shift.
  • Replies 50
With your new setup and stoopid fuel, what is the power band like with your new setup Paul? Your car used to be only a suspension change and a decent brake kit away from being similar to Mark and Russ's old R32, albeit a tad less sharp because of the extra weight. But it seems you are moving more and more away from an all rounder. Not a bad thing, just curious to know whether you have already crossed that line wih the big single or whether it will be with the gearbox!??!?!?!?
very narrow....its silly...i want my twins back Roy :huh:
I know of someone who can be talked into selling his GTRS's to go bigger
Mine were not quite off the shelf items. Its those that i really need...otherwise id have to see if i could get them modified again. They had yellow dot actuators too...yours would be green dot items.
Edited by DiRTgarage
Domonic Rigoli told me that you know the car i have its robs old white one,he managed a 10.02 @143 on mickey Ts. I have only got a 11.1 @129 on 18 psi and 245x18 nexens.
even my car ran an 11.4 on dead turbos and street tyres.. with a full circuit setup :)
One of the reasons i got rid of my 9 second street car...& then got a gtr .
Gtr's to me were a good all rounder ,fast street,circuit,drag ...you can do much more with one than my pain in the ass ,cranky aspirated chevy on alcohol.
Dont get me wrong i love drag racing..but it can be f*ckin boring waithing in staging lanes all day lucky to get a couple of passes.
Although i do miss being able to mash the throttle at 100 k's...& paint black lines on the freeway for a couple hundred metres.
I think gtr's should be kept manual & as close to original type setups as possible...to me it seems kind of silly to turn a zilla into a back half , tube chassis,or glide with transbrake type of car and still call it a streetcar..to me doing that loses its appeal.
Each to there own though.
( I like dirt's gtr because its still original looking,fast,& retains most things as nissan designed it)
With You all the way there Mate,
Sounds like we come from a very similar background. Good to hear.
Cheers SCOOP.
