  • Replies 134
Posted Images
Nice mate. :laugh:
What technique did you use? I want to have a crack at this now! lol
Thanks, I had been thinking about it for ages before Sidd posted up, Just had to get motivated...
I did it hella ghetto stylez.. But like Sidd said, after having a crack at it and knowing what you need to improve the next time is good..
I just got like a shitty baking dish, this is where I went bung, it was a white one. Filled it up pretty high with water then got a glad sealable bag and filled it up with water and got some pegs and clipped it to a cupboard handle. Then I put a flash on a big can of milo and angled it a brown piece of cardboard (only thing I had lying around) behind the back dish. Then put camera on tripod with 100mm macro lens and manual and auto focused for some shots and tried hand holding it aswell. I shot some in AWB and Tungsten to get the blue effect...
Hmm, thats about it...
When i get home i'll post up my samples of splash photography, you have all got me motivated to do it again haha.
Sidd - Sweet photo, i'm guessing extremely low shutter speed because of the motion blur? Flash seems like it was on camera or really close because of the harsh shadows behind and hard light. I think it works with this pic!
Great photos people!
beautiful work man!! love it!!
Yup exactly once you have a crack at it you will know exactly how to improve for next time!!
Wonderful results for your first attempt man :laugh: Wish i had a 100mm macro lens tho!! That would have been sweet!!
Wonderful results for your first attempt man :) Wish i had a 100mm macro lens tho!! That would have been sweet!!
Cheers man. I was glad I had a go at it, I'm more then happy with the results. Stoked actually. The 100mm macro is a sick lens, and cheapish as well for what you get... I have kenko extension tubes as well but I don't think I need to get closer. I'm prob gunna have another sesh later if I'm not to intoxicated. If I get any good ones i'll post em up.. :laugh:
Edited by Lepperfish
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
