Thats exactly what Racepace told me when I asked them about building me a mines style front pipe with a 450awkw goal with my new engine. Bummer was that they couldnt make the pipe for me without me sending the car down to them though, seeing as all systems are custom made to fit.
Funny timing here.
Im having exactly that made up for my GTR, a Mines style front pipe in 2 x 3" leading to a 4" merge, its custom to accommodate the extra height. Is yours the same height as an RB30 block?
If so, it would work out perfectly for you as mines being used as a template. I can see about getting another one made up and ship it to you if you like.
  • Replies 477
Funny timing here.
is ben @ racepace making your exhaust?
Funny timing here.
Thanks for the offer but the spacer is only 20mm a stock RB26. I think RB30's are nearly 40mm taller.
I like your style too. Nothing will solve flow issues like a 4" front pipe!
rb30 = 38mm taller.
how many posts has there been in the past 15min haha
Haha no probs mate
Cheers :(
actually, my brother has twin pipes on his gtr, its an 'n1' cat-back system, i think its 3inch as well.
factory engine & sounds very tough/poppy BUT i havent heard his engine kick over for way more than a year now hehe (dont ask)
I was talking last night about this, if the price isnt too bad, ive decided to make both exhausts and see which one ends up being better, then selling the other one (as they'll both flow huge numbers anyway)
There may be a BIG HP twin 3" RB30 on this Saturday's cruise :(
Oh yeah? And to think I was going to go to Wakefield instead.....if you confirm how much power is "BIG HP" that could persuade me to come along :P
....i have a thought who it may be, its auto or manual?
OK...VERY VERY BIG HP :(
Mark, it's the NSW:SAU Putty Rd Cruise.
Oh, and it's members only....but you can join on the day :(
PS, Steve, it is manually shifted :D
ok, just measured my front pipes & they're 2.75inch which merges into a 3.5inch pipe.
i spoke to westside mufflers & the cost is $2200 for a 4inch s/s system which also includes modifying the front pipe collector to a 4inch pipe...bit pricey i thought, any other workshops recommended?
Oh, and it's members only....but you can join on the day :P
PS, Steve, it is manually shifted :(
lol, ok next guess; is it twin 3037's?
I know its not your car hahaha
Your fronts are those xforce ones you were talking about?
I have the HKS ones, they're roughly the same size - id go check but no veniers
That price isnt that bad, but i know you can do better!
im not sure what they are, could be xforce or hks, how can i tell? could be hks to match the rest of the hks system, fark knows!
i called liverpool exhaust, custom 3inchfront pipes to merge into 4 inch all the way to rear is as follows:
- mild steel with ceramic coating (the whole thing) = 4k
- s/s (the whole thing) = $4400
- 4inch mild without front pipes = $2200 (westside is the same @ $2200 but its s/s)
he recommends i go mild steel with ceramic coating but to coat the entire thing is a bit of overkill, thoughts?
apparentely mild steel is more flexible for knocks & bumps, more suited for our great aust roads!
No, it's definitely not my car - it only made 411rwkw on 16 psi a few years ago now
Oh, and it's the Bells Line Of Rd Cruise, not Putty Rd (which is end of year). Same meet point though.
$2,200 is a bit steep. Last time I bought 4" 316 stainless it cost me $45-50 each bend. Exhausts would be 304 grade. I could get a twin 3" done for under $2,000.
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
