Hi,nice to meet u all down there. I've a question about the coolant.
"Heat is turbo car killer, right" And most of the people said that add 50% of coolant and 50% of water into the radiator,and that is the correct formual, right. Here is my silly opinion.
If add 60%of coolant and 40% of water into the radiator, will it be more effective for cooling down the engine?
Or 55% of coolant and 45% of water! So i wonder is anyone has that experience about that. Becasue soon i need to flush the radiator and change the coolant. Therefore, i had that idea in my mind.
Cheers mate
Steven
https://www.sau.com.au/forums/topic/27793-question-of-coolant/
Well the last time I flushed a radiator I used 100% coolant, purely for its non corrosive nature, I dont know if it would make a huge difference to the ability of the radiator to exhange heat - in I doubt it very much.
I was under the impression that coolant served two purposes, to extend the boiling point of water and inhibit corrosion.
water is actually more effective at cooling
but it corrodes like there is no tomorrow
also the coolant acts as a layer in the system to the water doesnt boil like crazy
btw u can buy antifreeze antiboil seperate or as a 50/50 mixed solution
The higher the concentration of glycol in the system, the lower the heat transfer capability of the coolant. So if anything you would want to _reduce_ the coolant concentration to ~30%. No less than 20% howeever. But in either case, it wont have really any real effect on turbo temps on the street.
Alot of ppl get confused and think the glycol (the green shit) in coolant does the cooling in the engine. On the contrary it actually impedes it slightly (compared to straight water) but offers antifreeze/boil protection aswell as caviation/corrosion protection.
Yep, you have pretty much hit the nail on the head, Busky...
Aim for between 33% - 50% Ethylene Glycol mix, as this has a good balance of the superior heat transfer ability of water and the advantage of a broader operating temperature range with the Anti-boil properties.
It's possible with 50% concentration to get a boiling point of around 109 degrees Celcius instead of the usual 100 degrees. This is good in the extreme case of a failed cooling fan, for example, and avoiding the possibity of hot-spot damage which used to badly damage the alloy heads of early RB30's and VG30's by cavitation...
When you buy coolant, read between the lines for the properties. An excellent concentrate will have at least 1000g/litre of glycol. Anything less like nasty cheapo brand ready made and diluted coolants have concentrations as low as 30g/litre. It's pretty much green cordial!!
Thanks mates. So i think it was my silly idea. what about change the radiator perssure cap, will it be help? Our factory cap is o.9Bar, what if changed to 1.3 Bar perssure cap. How's the effect? As i knew is, after changed the higher level perssure cap, the fun will open more often , and could keep the tempture down esaier. Is that right?
Cheers
steven:D
Nope. Another wrong idea.
The reason we use pressure caps is to hold the coolant at a particular pressure. A pressurised system will have a higher boiling point, say 5C higher at 1 bar (Im not sure of the exact figures). The cap will not allow the pressure to exceed its rating by bleeding off the exess into the overflow bottle so it doesnt cause damage to the pipes/radiator etc.
However its not necessary to increase the stock cap pressure unless your coolant constantly hits >95-100C and you need that extra anti boil protection. In most cases, you've probably got a stuffed radiator or a malfunctioning thermostat in order to warrant a higher pressure cap. Unless of course, youve got a T88 hanging off the side of a 2JZ and do circut racing or something...
Most coolants on the market are glycol based, glycol is more effective than water for absorbing heat..
More glycol more heat can be extracted from your engine, but your cars cooling capacity, must be efficient enough for removing
the heat from the cooling medium, so not necessary the more coolant the cooler your car can run, glycol will retain heat if you do not have the capacity to cool it down...
But bear in mind that if a concentrate glycol coolant were used over around 65% with water, you would actually have overheating problems. You are correct though about the car's capacity to actually remove heat in the first place. Not trying to sound smart, but glycol has the ability to stabilise and transfer heat more evenly than water - nuclear thermodynamics.
Here is some links to specs on good quality coolants:
http://www.nulon.com.au/content/tech_ll.htm
http://www.castrol.com.au/products/pdf/B11...reeze%20350.pdf
hmmm, you're not supposed to mix two different types/brands of coolants. reason being that they can actually react against eachother and accelerate corrosion. Should try to at least drain the radiator and undo the drain plug on the block. otherwise, drop the bottom radiator hose and drain it all and flush the whole system with a hose while the heater is set to hot and turned on. that way, you'll get rid of all of the old coolant running inside the car for your heater.
Lets clear up some issues....
Glycol is generally more viscous than water and has a lower heat capacity and thermal conductivity than water. Therefore has a lower heat transfer properties (than water) as the glycol percent (based on a water/glycol mixture) is increased...
These are the boiling points of a Ethylene Glycol mixture with water with E.G in weight percent mixture within the water
0% 99
10% 100
20% 101
30% 102
40% 104
50% 106
60% 110
70% 115
80% 123
90% 140
100% 160
Therefore using something around 40-50% sounds right.
I hope this helps guys!
:uh-huh: yeap! :uh-huh: spot on. although those figures will vary slightly depending on the brand and concentration of the ethylene glycol content of the coolant. I couldn't find a link for Tectaloy, but the Nulon and Castrol links in my previous posts point to what i consider the main players of concentrates.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
