ive just booked out a tuning arvo at ahg, has anyone else done one of these? i cant seem to get much info from ahg
what can i expect, do they just let you get out there and drive or is it more like a driver training?
any info would be great so me and my mates get the most out of it
Cheers
https://www.sau.com.au/forums/topic/278051-tuning-arvo/
The Tuning event is usually on there little circuit and does not include any driver training or instructors, but they will keep an eye on you to make sure that you don't do silly things. They are a good event to do once you have recieved some driver training, but I'm sure you'll have fun regardless. Whilst the track looks really simply, there are a few interesting technicalities.
https://www.sau.com.au/forums/topic/278051-tuning-arvo/#findComment-4699996
  • 1 month later...
Well had the track day yesterday and all i can say is im booking another one on monday, :(
Weather was crap but had soo much fun, they are changing the tuning arvo slightly so that there is a little more driver training involved, seating and hand position, race lines and just answering general questions.
We got to use the the main track, 2 or 3 laps then swap over. And we also got to have a go at the skid pan which showed us all how bad we really are at driving in the wet lol, with 10 people there wasn't much waiting in line to get on either of the tracks.
Would highly recommend it to anyone. :P
https://www.sau.com.au/forums/topic/278051-tuning-arvo/#findComment-4769823
the guy we had was awsome, said drive within your abilities. He let us have some fun but also helped us get better as the day went on. the only thing he said was no hand brake drifts and if you spin out dont just keep spinning your tyres, one guy got banned from the track at the end for doing a burnout.
https://www.sau.com.au/forums/topic/278051-tuning-arvo/#findComment-4770129
hey, we had the tuning day on the thursday and it was p*sing down. it showed up every little handling fault and driver fault. although it was good fun bouncing on the limiter in 3rd gear. they told my work mate to leave after his exhaust fell off his bridge ported RX6. apparently it was all the ladies in the office could hear lol
https://www.sau.com.au/forums/topic/278051-tuning-arvo/#findComment-4771189
Would highly recommend it to anyone. :D
Glad to hear that there is some additional input from the instructors, as they have alot of valuable information to impart :D
Yep, they are great fun :down:
https://www.sau.com.au/forums/topic/278051-tuning-arvo/#findComment-4771419
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
