Hey guys, sorry to bug everyone. Used search function and couldn't find anything regarding this. On my cluster (S2 cluster in an S1 R32 GTR) I always have the HICAS light on, fair enough I have a lock bar, however the past few days I have noticed that one of the other warning lights is on at the moment, looks like this (!)
Not sure what to make of this as I have looked through a few manuals and what not and have not found any helpful information. Wondering if it would be a good idea to take it somewhere, hook it up to a computer and see what's what? If so where would people recommend? All the work done to my car has been through X-Speed, however I don't have the luxury of taking a day off during the week to take it down there due to work commitments so can anyone recommend a garage with required equipment for a Saturday? (Probably not but worth a try...)
Any help on this would be greatly appreciated,
Thanks,
-Chris
https://www.sau.com.au/forums/topic/278075-what-the/
Like Brad said, thatds the handbrake light. It comes on when the handbrake is up, or when you have low fluid in the brake master cylinder. It could mean your disk pads are low so you need to replace them (they'll be VERY low if this is the case) or you have a leak somewhere, probably very small. Just under the car and have a look behind all the wheels to see if you can see anything.
https://www.sau.com.au/forums/topic/278075-what-the/#findComment-4700064
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
