GT2860-5 turbos (340hp each)
stainless manifolds, dumps, front pipes and HKS actuators
less than 7,000km old
reason- want 550-600hp at tires these wont do it
price- swap for big single and cash adjustment
these will make 450-500hp max depending on setup
cheers
ok whiteboy01 is first in to buy the kit but would rather swap
but i will look around for a kit to put on if i find one i like they are yours whiteboy
cheers
  • 1 month later...
Still available!
If so have whole turbo kit. Trust stainless steel manifold, HKS T04R Turbo, trust type c watsegate, oil lines, return line, custom dump, 4inch turbo inlet pipe with k&n filter, custom turbo outlet pipe(all hpc coated) Can supply picsif interested.
Will deal as long as i get dump pipes all the way too cat conv., Turbos are still good. Get inlet stuff aswell.
If interested, let me know as everything is still on car! Makes 357rwks on 18.5psi.
Louis: 0404 737 906
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
