Hey guys. I've noticed that since about yesterday, my oil pressure reading is looking rather low from what it is usually.
I'm not getting the warning light, however, it's sitting within the closer half to the 0 and first mark point on idle (warm engine), and it's not moving much when revs climb (even up to 4-5k RPM). I only notice this difference now because previously the reading moves a fair bit with different revs, and it's certainly obviously higher pressure at a cold start, but it doesn't seem to be reading near the same now?
I have checked for any leaks, oil level is fine (checked 4H after the engine was last run). Oil temps are normal too. Apparently the stock gauge is not super accurate, so should this not be trusted? I'm not noticing any other issues when driving either.
My current setup is:
New R33 crank (not sure if worth mentioning), N1 Oil Pump, a stock sump with a Tomei baffle plates and a Tomei 1.5mm restrictor to the head.
Your advice is appreciated - I am a bit paranoid about this, since my motor spun a bearing last year, and I've spent quite a fair bit on my new setup (only 3 months old).
Cheers!
https://www.sau.com.au/forums/topic/278484-oil-pressure-concern/
Get it checked ASAP either way, i wouldn't be driving it personally with a built motor as well... get it towed - sensor checked/replaced and go from there.
Wont hurt to change it or put something aftermarket on anyhow
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
