I just got a Power FC and want to test a Z32 AFM that I think may be dodgy on it.
What I need to know is whether the voltage displayed in the monitor section is the actual voltage or modified voltage. To explain it better if you were to run a eManage Ultimate and then monitor AFM voltage through consult then it won't be displaying the actual voltage, it will be displaying the voltage adapted to the ECU.
Cheers,
Adrian
https://www.sau.com.au/forums/topic/278725-afm-voltage-on-power-fc/
One more question, this Power FC was running on a car with exact same mods as mine(RB20, GTR injectors, HKS2530, Z32 AFM etc) and had a pretty good tune so I was hoping to just get it checked to make sure tune was safe.
However I have just put it in and turned key to on(car is not currently able to run) and 'R32 Standard' was highlighted in the AFM settings. Also I noticed all injectors were set to 100% and no timing changes.(I would have thought instead of 100% it should be 440/270 so somewhere around 60%)
Could this have been tuned in some other way(just changing a/f settings to make up for the change in AFM and injectors)? If so do any Power FC Gurus know some points in the standard map that would have to be changed so I could check and see if this is the case?
Cheers,
Adrian
Edited by Kwyjibo
the guy has probably reset it, you should reset it when you install it in your car anyway
i would be very cautious running someone else tune, even with the same mods
could be a timebomb, and it may time longer to fix someone else;s tune than a complete tune
i dont get your real vs actual, it will just display the voltage on the AFM wire
Yeah don't worry was always planning on getting a touch up tune straight away to ensure its safe.
Pretty much answers my question. What I meant was is the 'monitored' signal the actual voltage coming from the AFM or is it modified by the Power FC and then shown. My eManage example is because that is what I was originally going to get and it modifies the signal before it reaches the standard ECU. Obviously the Power FC as standalone so I wasn't sure whether it showed the actual value or a value modified based on which AFM you select.
the voltage displayed under ETC, SENSOR SW CHECK and MONITOR, 1 CHANNEL, AIRFLOW is the unadjusted voltage
the PFC doesn't adjust the voltage as part of the tune, it uses the base voltage in arithmetic like this;
SELECT LOAD from AIRLFOW TABLE
WHER VOLTAGE = Lookup(AFM1)
then it applies correction to the load index and goes from there.
the voltage is never adjusted by the ECU, why would it?
only interceptors modify voltage inline like you said as this is the only way
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
