Have got my turbo gear up for sale. converted back to NA due to compressor bearings failing and not having the funds to get it rebuilt/the time. most of this gear (well all of it, cos thats why i bought it :thumbsup:) would be suitable for anyone looking to convert their NA to turbo.
- standard GTST airbox w/ snorkel -$75
- standard side mount intercooler piping not all parts are here, only some - $40
- standard R33 GTST crossover pipe. sanded down and sprayed in engine enamel black, comes with vacuum line bracket - $50
- standard RB25DET heatshielding (for manifold and turbo housing, painted in engine enamel black) - $20
- standard R33 GTST side mount intercooler (flushed clean) - $75 SMIC
- standard R34 GTT side mount intercooler (flushed clean) - $150 SMIC
- standard R33 GTST ECU (manual) - $150
- turbosmart Supersonic BOV (ajustable, single port, comes with RB20/25 adapter) $150
- brand new Monza oil/radiator catch can, never used. comes with all fittings/brackets/lines etc - $50
as well as this gear, there is also an ECU up for grabs. was chipped and maped by Toshi to suit an RB25 with hi-comp (ie NA motor), a bosch 040 fuel pump, standard turbo, injectors, intercooler, for 7PSI. never got the ECU as the day i put the order in my turbo died, so its still with Toshi. PM him for details/price here: http://www.skylinesaustralia.com/forums/Toshi-m1094.html
prices do not include postage, but for most of them, shouldnt be too much :3some:
post your interest here or just PM me if your interested.
Josh
https://www.sau.com.au/forums/topic/278847-rb25-turbo-gear-extras-remapped-ecu/
- brand new Monza oil/radiator catch can, never used. comes with all fittings/brackets/lines etc - SOLD
also remembered i have a boost guage.
- 52mm Calibre boost guage w/cup. numbers light up blue, needle orange, white face. $40
REVISED PRICING
Have got my turbo gear up for sale. converted back to NA due to compressor bearings failing and not having the funds to get it rebuilt/the time. most of this gear (well all of it, cos thats why i bought it ) would be suitable for anyone looking to convert their NA to turbo.
- standard side mount intercooler piping not all parts are here, only some - $40 $30
- standard R33 GTST crossover pipe. sanded down and sprayed in engine enamel black, comes with vacuum line bracket - $50 $30
- standard RB25DET heatshielding (for manifold and turbo housing, painted in engine enamel black) - $10
- standard R33 GTST side mount intercooler (flushed clean) - $40
- standard R34 GTT side mount intercooler (flushed clean) - SOLD PENDING PAYMENT
- standard R33 GTST ECU (manual) - $150 $100
- Calibre 52mm boost guage w/ cup - numbers etc light up blue, needle orangy/red, dims with your lights. includes plug and wiring for power - $30
Josh
  • 1 month later...
hey no im still planning on gettiing it..
pm'd u again
yeah, could pretty much say it has. PM me an offer
Edited by r33canada
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
