Original thread here
Hey everyone. It's time for another meet!
This time we're heading down the peninsula for a day cruise.
It's a great route with plenty of fun corners and amazing scenery.
We'll meet in the morning and have a few stops along the way for photos and lunch.
Any Japanese import can attend (don't bring down your mum's Mazda 2! :D).
When?
Sunday July 26th.
10am meet for an 11am departure.
Lunch at around 1.30 and arrive back in suburbs mid/late arvo.
Where?
Initial meetpoint: Bunnings car park. Corner of Cheltenham Rd & Springvale Rd, Keysborough.
Destination: The peak of Arthur's Seat.
Route:
View the route in detail by clicking here
Distance:
Roughly 120km. ~1/4 tank of petrol for most people.
What to bring:
- 1x jap car
- Petrol (at least 1/2 tank to be safe)
- Money for lunch
- CB radio (optional)
- Camera (optional)
Let me know if you're coming so we can get a rough idea of numbers.
Hopefully see you all there!
Cheers.
https://www.sau.com.au/forums/topic/278919-sei-day-cruise-26th-july/
  • Replies 180
Stay late at an already paid for trance night...
Or SEI cruise.
Damn that's tough.
I'll leave it in the hands of the panel shop who will be repairing some damage to my car that week. If she's good and ready I'll come :D
Might be there provided my girlfriend can bring her skyline too...so sick of being the only chick driving at these things...
i dont understand if you are asking if your girlfirend is allowed to come (which she is) or that you'll come only if she is able to make it to the event. either way, you wont be the only girl driving. cassandra is too.
A bit of both! :D
doesnt really matter if it does :D Still happy to drive in the wet :P
Says you with the GTR :)
I think everyone will enjoy it more if they're able to drive through the twisties without the fear of writing off their car.
I went up Arthurs Seat in the wet once and it was quite scary. People sliding everywhere.
Well that is a fair point. One of my colleagues who does shift work asked me yesty morning as he was about to go home if it was very slippery and wet outside.
I told him i never notice anymore :P
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
