u can get it for around $500 or less if u get it off nissansilvia.com, or even a trader off here will have a deal that is cheaper than what u have been quoted b4. off the top of my head for the same clutch u mentioned it was about $496 + $20 postage off ns.com
" Pressure plates and clutch plates provided with these clutches are oem bundled released direct from Daiken, RPM or Seco and are not Pink or Purple like the boxed Exedy items unless listed as Exedy."
Make sure you get EXEDY .. I only use the pink clutch covers with pink cushioned button clutch plate
I'm running 360hp in mine with a twin plate clutch, handles beautifully. Though every once in a while it does grind a little heh, fkn noisy twin plates...
Was looking at getting one of these if mine ever fries.... http://www.nengun.com/exedy/hyper-carbon-c...in-plate-clutch mmz.
Tenegah have a deal on supply and fitting of genuine Exedy's
http://www.skylinesaustralia.com/forums/Ex...rt-t279096.html
Be very careful of some of those "too good to be true" prices, as quite often they use some non-genuine parts in there kits.
^^ sounds good to me, am i doing any damage to my car driving it with a very slipy clutch? dont have the funds to buy 1 for a couple of weeks
cheers
You won't be doing much damage, but don't drive it too hard. Tenegah will have your standard flywheel faced, so it should be as good as new :D
i remember a thread created by someone who discussed all the different types of clutches with their pro's and con's. anyone know where this has gone???
i need a new clutch for rb20 and heard twin plates faark rb20 gearbox's so researching on whats best
anyway ideas???
I've got an Rb20 turbo 5spd in my ceffy, and i can tell you that if i had a twin-plate, i'd be on the side of the road still. a single plate heavy duty organic is the go for that particular gearbox.
ring auto clutch in osborne park. got one of his clutches behind my 25, feals like standard and takes anything stock internals can throw at it for around $300-350 with machined flywheel, thrust bearing and spigot bush
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
