u can get it for around $500 or less if u get it off nissansilvia.com, or even a trader off here will have a deal that is cheaper than what u have been quoted b4. off the top of my head for the same clutch u mentioned it was about $496 + $20 postage off ns.com
" Pressure plates and clutch plates provided with these clutches are oem bundled released direct from Daiken, RPM or Seco and are not Pink or Purple like the boxed Exedy items unless listed as Exedy."
Make sure you get EXEDY .. I only use the pink clutch covers with pink cushioned button clutch plate
I'm running 360hp in mine with a twin plate clutch, handles beautifully. Though every once in a while it does grind a little heh, fkn noisy twin plates...
Was looking at getting one of these if mine ever fries.... http://www.nengun.com/exedy/hyper-carbon-c...in-plate-clutch mmz.
Tenegah have a deal on supply and fitting of genuine Exedy's
http://www.skylinesaustralia.com/forums/Ex...rt-t279096.html
Be very careful of some of those "too good to be true" prices, as quite often they use some non-genuine parts in there kits.
^^ sounds good to me, am i doing any damage to my car driving it with a very slipy clutch? dont have the funds to buy 1 for a couple of weeks
cheers
You won't be doing much damage, but don't drive it too hard. Tenegah will have your standard flywheel faced, so it should be as good as new :D
i remember a thread created by someone who discussed all the different types of clutches with their pro's and con's. anyone know where this has gone???
i need a new clutch for rb20 and heard twin plates faark rb20 gearbox's so researching on whats best
anyway ideas???
I've got an Rb20 turbo 5spd in my ceffy, and i can tell you that if i had a twin-plate, i'd be on the side of the road still. a single plate heavy duty organic is the go for that particular gearbox.
ring auto clutch in osborne park. got one of his clutches behind my 25, feals like standard and takes anything stock internals can throw at it for around $300-350 with machined flywheel, thrust bearing and spigot bush
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
