Hi all! got some items to clean out
OS Giken Twin plate push type clutch Suits R32 and R33 just been rebuilt by NPC has not been used since rebuild - 1300
Bolt on spacers 15mm 5x111.4 - $60 pair
Bolt on spacers 20mm 5x111.4 - $80 Pair
contact 0432 594 588 or PM
pics to come!
pics to come!
hey mate is this a ts2cd to fit 32 gtr?
