  • Replies 87
this question is kinda void tho..
Not really, yes we can all drive these things hard, but usually (ie during the work week) we would drive the same/similar routes at similar speeds.
Also, I would assume that you know what you "usually"get, yes?
Yes this is true, 500km on average around town driving..
tho i still dislike the way the gauge works. often when i do fill up 60L is all that goes in..
i'm still yet to settle down driving it... doesnt look like its going to happen anytime soon tho..
Now as for this emanage ultimate.. how much do they cost, are they easy to find second hand.. are there any certain models you need to look for. and loom for which model is the go?
you can get them new or 2nd hand, there are no moving parts so they are very reliable. there are 3 looms, main, injector and ignition. im not sure how they are sold these days since i got my ultimate 2nd hand. and the looms are all universal, however you can get plug and play things so you dont have to chop up the factory loom, you cut up the 'extension'. then comes the tuning
but the best thing is if you plug it in and zero all the settings, you can drive it like normal till you can afford to get it to the tuners........
yeah it sounds easy (it sorta is) the hard part is finding the pin outs of the ECU. i have a sheet but when i metered the 12v out, it wasnt there! so i didnt want to risk it....
anyway we have 1 successful install anyway!
nope i dont think so! only to about 3-3.2k then its locked all the way to........i guess 180 lol
Oh, thats right, you still have a speed limiter... :blink:
Thanks Andy, its a bit far to take it, but I will call if the local specialist has trouble.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
