you might be better off getting aftermarket shocks from Import Monster or im sure ive seen several sets of stock shocks!
that said, someone has some tanabe coilovers to be installed and he will probably want to move his stockers. so you may be in luck!
thanks i'll have a look
still looking?
Won't know until I get my suspension. Sorry mate.
Dunno how much and I dunno when.
Maybe check some of the wreckers in NSW, I believe there are a few M35's collecting dust up there.
