wouldnt really recomend putting them in the kick panels, tweeters are great for raising the sound stage and lifting the whole sound up of the floor, to put them in the kick panel would sort of defeat that purpose. A piller is a very popular place to mount then or the door sail (the little pannel that covers the bolts for you rear view side mirror's). either of those are good locations. the sail is the best as it is one of the cheaper parts to replace. i myself have actually just wedged them between the window and the dashboard. sounds dodgy but no holes or anything cut into any panels and they look mint.
and untill i have money to make custom moulds on a pillers thats were there staying.
Problem is the the speakers have not been listed and wether the midwoofers have been mounted in stock locations. Being a West Austrailan SQ judge ive heard many different set up's. Using the kick panels can be a great way to achieving depth in a system it all depends on what speakers are being used. The stage height normally wont be as high but with good equlisation and speaker directions it can be fixed. What i would do is allow the tweeters to be moved around while wired up and try blue tacking them in a range of places to get the best results. You'll most likely find the tweeters will probably perform there best in the far back corners of the dash/a pillars aiming at the other sides head rest. Sail panel while being cheap and easy may not get the depth your chasing... thought i would add my 2 cents.
agree with everything you say, as yes sail panel is a cheap and easy option thats the reason i offered that location for the people out there who dont want to spend lots of money geting custom made a piller mounts or things like that. bluetacking is a very good option aswell. all in all i am really just agreeing with everthing you say. but like you said adding mt 2 cents
just use the surface mounting hardware, put them on the a pillar. if you need to remove them, just get a new pair of pillars, its not like its a brand new car or anything. just make sure you test them with bluetack first, like the others mentioned.
I have mine installed up on the A-Pillar. I've attached a couple of pics to show L&R, they look reasonably standard so they don't attract too much attention from prying eyes.
Pardon the shit pics...
Edited by -Stokesy-
Not something i would have ever chosen to do but the previous owner of mine surface mounted the ones in my car in the door card. They actually work quite well there. I dont go much on cutting huge holes in the doors but if your not planning on ever taking them out i guess its ok...
That's not really true there are many advantages to having your tweeters in the kicks:
- There's more room
- They're not on display
- They're an equal distance from the listener as the mids
- you can create a deeper sound stage as they are further from the driver
Just have a play around with different locations and see which sound you prefer.
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
