Hi all,
Selling my Volks as I have upgraded to 19s. I would really like to see this on another sedan if possible. Offsets would suit coupes as well but won't look as agressive as compared to on a Sedan.
18x8 +33
18x9 +31
Tires are 225/45 Sumitomo HTR ZIII 70%; 245/45 50% $1100 when new
Tyre review here: http://www.tirerack.com/tires/tests/testDisplay.jsp?ttid=93
Come with additional CF Rays wheel caps as well which cost me an additional $200
Selling the lot for $2800 pick up Southside Brisbane. If you are planning to stick this on your sedan, you will need to have been lowered at least 1" and rolled your rear guards.
Will also suit R32,33,34.
Wheels are flawless and the closest you will get to brand new!
PM for more info.
https://www.sau.com.au/forums/topic/279581-fs-volk-gts-top-secret-gold/
  • 4 weeks later...
  • 4 weeks later...
  • 4 weeks later...
  • 1 month later...
Boxing day sale reduced to $2300!
Perfect for lowered V Sedans, R32,33,34 and most Nissans!
What you get:
Wheels x 4 in immaculate condition
Sumitomo HTR ZIII performance tires with plenty of thred left
Rays CF Wheel caps
* If purchased at $2300 will thrown in a set of used Blue rays duralumin lug nuts as well!
Treat your car to a set of these for the New Year! :D
  • 5 weeks later...
  • 1 month later...
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
