Hello there,
I was wondering if there is a turbocharger (kit?) that is good up to 325-400HP and just plugs in like the original.
By 'plug in' I mean that I want to install back the standard heat shield so the engine looks neat and genuine.
Cheers from London,
Andrew
You could go a highflow, or something like a HKS 2535/GTRS etc. All bolt on kits and can retain factory shields.
Hi there ...
Thanks for the quick reply..
I see that you have a S2 too :)
Mine is a late 1997, I guess one of the last ones build?
I will check out your recommendations.
Foremost I'm looking for quick spool up time and wide power band.
Cheers to OZ!
Edited by Torques
Hey there, To keep your engine bay looking nice and neat and stock. The best way is to highflow your turbo. You can contact hypgear turbo chargers on these fourms, you'l see him floating around as i have one as well. im doing 230-240kws on mine. Turbos are very good with high boost.
Hi there ...
230KW sounds quite nice.... and about right for my car.
I'll check it out (but what is HighFlow?) (sorry for the question, I got the Skyline just 8 Months and it was sitting mainly in the garage since I had to work abroad)
Btw.
Is it of any use to adjust the lever of the actuator just a few millimeters.
I was thinking that this might shift the whole boots curve a bit higher while still maintaining the overall boost level adjustment done by the ECU.
Or do I risk that the swing valve does not close fully when it should be fully shut?
(I'm just thinking aloud and have no idea whether the actuator is adjustable at all)
How much do you want to spend and what is your ultimate goal? You can get some immediate extra zip by getting an electronic boost controller and upping the boost to 10 -12 psi. Get a Nistune chip http://www.nistune.com/ to make you computer tunable. (Or if you aim for big horsepower get a Link computer http://www.linkecu.com/ ) Get a high flow panel filter for your stock airbox and a three inch turbo back exhaust. If you have a spare car you could send your turbo to GCG http://gcg.com.au/ to rebuild/highflow it to support 450hp or buy an HKS kit that will drop straight in (but more expensive). The Link and Nistune websites list stockists worldwide.
Spend a few hours reading this site. Its all there!
PS sorry just noticed you car - nistune may not be available for your car - you may need to install an R32 ecu first (assuming you're not auto).
In lamens terms it's using a stock skyline turbo shell and completely rebuilding it to make it flow more air and using steel wheels to allow more boost pressure.
Hi!
Yeah I thought so, but is it worth the effort?
Wouldn't it make more sense buying a modern ball bearing unit?
How mach does the conversion cost?
Cheers ..
Hi there ...
My ultimate goal would be getting more power (300-330 without ripping the car apart and keeping the appearance of the car more or less stock:)
I read that about 310-330HP (is this rear wheel?) should be achievable without changing too many components.
The standard turbo is said to be good till 13 psi.
As for the ECU I'd love having Nistune, but as you said, it's not available for the R33ECU it seems (such a shame)
The R32 ECU has no Variable Cam Timing, and that's something I'd like to keep.
I read that you can use some ZX300 ECU, but I think that's a bit shaky .. (as for the loom etc)
The PowerFC I don't like since you can only tune it with this HandCommander, and I want to use a Laptop-Computer where I can store all the data and curves.
The LinkECU sounds promising, but it costs an arm and a leg :( (but it's on my radar)
As for the turbo I could buy a used one for little $$ and have it rebuild to HighFlow.
I think I should get a boost controller and a good boost gauge and toy around with higher boost levels (and see how the engine reacts).
I like the mechanical bleed valves as for their simplicity and their low price.
The electronic boost controllers are neat, and overpriced but if I come across a good unit with scramble mode and boost pressure display I'll go for it.
I have bought the Blazt cable and some software since I want get a feel for the engine's parameter.
I did a lot of serious tuning on motorcycles so I'm not starting from scratch :D
Cheer from London!
Hi there ...
Easily
Not if you want the ceramic turbine to stay attached
Try a search on "datalogit".
The LinkECU sounds promising, but it costs an arm and a leg ;) (but it's on my radar)
The most important question for you to answer, what ECU is your tuner experienced with?
Yep
Quite dangerous if you don't know what you are doing, plus the standard ECU wil beat you every time.
Try a search on "+rich+retard".
Waste of money, keep it simple. Especially if you are going to use the ECU to control the boost later on.
I did a lot of serious tuning on motorcycles so I'm not starting from scratch :)
Turbo charged motorcycles? Once you add boost you will be surpised at the changes it makes to your tuning experience.
Cheer from London!
Oh well, never mind :)
Cheers
Gary
Damn you guys beat me to it lol. Yep search up Datalogit dude.
Hi there ..
I knew about Datalogit, but I think it's too much clutter and too expensive for a functionality other ECUs come with anyway.
Hi there and thanks for the answers :)
Easily
Would be a shame if it came off, wouldn't it? :)
I read that the standard turbo is good for 11-12PSI.
Some claim even 13PSI ..
Now that IS VERY interesting since nobody ever mentioned anything about "+rich+retard" for stage I where I was reading.
But if I increase the boost in small steps, to 9-10PSI shouldn't it be safe?
I like 'keep it simple', how does a new EU control the boost?
Is it using the already build in boost control valve?
Nope just NA engines, but a turbo engine is not much different (except for the turbo of course ;))
ok, just to give you a quick run down on rich and retard, it isn't a boost based thing. it is based on airflow. so if you accelerated in the right way you could probably get close to hitting 15psi at higher rpm with the stock ecu, or if you just stomp it off the line you would probably hit it at about 13psi. the actual pressure has little effect on whether the ecu goes into rich and retard mode. when the ecu sees excess airflow it backs off the timing and richens up the air/fuel ratios. so if you want anything over about 205kw you are definately going to need some sort of aftermarket ecu solution.
as for the turbo, the highflow turbo is going to be the most direct bolt in turbo, as it still uses all the stock oil and water lines etc. it doesn't help you much, but there are plenty of places here that do ball bearing high flows
Thanks for the run down :ninja:
Is it possible having the standard ECU remapped (like a Mines ECU) to get around the R&R?
As for power I read the following
injectors max out at around 340 bhp
afm max out............around.340 bhp
fuel pump max........around 350 bhp
standard turbo, max boost .8bar, max power 330bhp ish
standard ecu max power 330bhp ish
standard clutch.....340bhp max
Now you guys tell me that the standard ECU is no good for anything over 274bhp .. :)
Cheers ...
The Standard ecu cannot be remapped. the closest thing is to get a new daughterboard fitted and get a custom chip for that, but that's quite costly. If you get an R32 ecu and chip that you can get a black box to do the vvt but really you may as well bite the bullet and get a Link c/w boost control and their knock detectors. If you want to tune your own engine you will need minimum some kind of knock detection, a wide band O2 meter and pref an exhaust temp guage.
The GCG highflow is effectively a new turbo in that all the components are replaced. It is not cheap however at around AU $2000 which is still less than a new turbo with fitting kit. You can get bush bearing highflows for less - they don't spool up quite as quickly and may not last as long.
Thanks for the run down ;)
Now you guys tell me that the standard ECU is no good for anything over 274bhp .. :D
Cheers ...
Kinda right...
Injectors - 220-240rwkw
AFM - 220-240rwkw
Fuel Pump - change by default, simple as that
Stock Turbo - 220rwkw
Stock ECU - 170-200rwkw (it varies per car based on many variables)
Stock Clutch - 160rwkw, much more power its on borrowed time and will fail.
The ECU generally is the most limiting factor, but then injectors & AFM come into play not too much further so its much of a muchness to be honest.
Most people usually have upgraded the clutch too long soon as they increase power. Especially if its 15yrs old
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
